Project Wicked Bad *** !
Old Jan 10, 2013 | 09:12 PM
  #61
GNR22's Avatar
GNR22
Originally Posted by f150inline
I am not trying to start off here on a bad foot but you are wrong. A limited slip will not lock the wheels together like a true locker. You can have true 4 wheel drive with lockers it will just handle funny. When I go one ton I will probably run arbs front and rear so I can have 4wd and no weird handling. besides if he is going one ton he obliviously plans on wheeling hard and wants the dependable lockup that you cant get with a limited slip.
And when he's wheeling it hard, and breaks an axle shaft, and breaks bones from the wheel snapping back, don't say I didn't warn you about it. Another user on this site, 77mud if I remember correctly, had that happen to him and now keeps his front end open because of it.
You're right, it won't lock the wheels together. But, do you want your steer wheels locked together? When the truck turns, the outside tire spins more, you don't want to use 4x4 on anything that you actually get traction on then because your truck is going to hop around and break parts.
You can tell me I'm wrong, but I am NOT arguing the effectiveness of traction that you will get with a locker. I'm arguing the practicality of it as well as the safety aspect.
Old Jan 10, 2013 | 09:29 PM
  #62
f150inline's Avatar
f150inline
You are confusing a spool with a mechanical locker a spool truly locks your wheels together while a mechanical locker will allow the wheels to rotate at different speeds when there is no power going through the drive line. The reason that mechanical lockers cause weird handling is at first they are locked causing understeer then they unlock suddenly and cause snap oversteer.
Old Jan 11, 2013 | 11:48 AM
  #63
GNR22's Avatar
GNR22
Ah, yeah you're right. I apologize.
Old Jan 11, 2013 | 02:08 PM
  #64
firerescue9's Avatar
firerescue9
Lol you guys are confusing me!
So should i or should i not run a lock-right in the front?
Old Jan 11, 2013 | 02:35 PM
  #65
GNR22's Avatar
GNR22
I still wouldn't run that in the front. I would still run a L/S unit. I still find it very useless to run a spool or locker in the front end because turning on any ground that you have any sort of traction will cause your truck to jump around.
Old Jan 11, 2013 | 04:34 PM
  #66
f150inline's Avatar
f150inline
Don't worry about it
Old Jan 11, 2013 | 04:36 PM
  #67
f150inline's Avatar
f150inline
Thats basically what I got its not that bad, but its really personal opinion and what you are looking for.
Old Jan 11, 2013 | 08:01 PM
  #68
Encho's Avatar
Encho
The Southernmost Mod
Gnr, a locker will only have an effect if the truck is in 4wd, otherwise the hubs will turn alone, so, actually, a mechanical locker makes quite a lot of sense in the front axle. Air and electrical lockers work great for the rear.
Old Jan 13, 2013 | 08:53 AM
  #69
firerescue9
This to me is a complete waste of a good truck. Seriously...what is wrong with people?
Right where chevys belong! On the tow truck and off the streets!!!
Old Jan 14, 2013 | 05:30 PM
  #70
Fastback460's Avatar
Fastback460
I gotta agree with you man, I don't see any sense in putting a spoiler on a truck :P
Old Jan 14, 2013 | 10:56 PM
  #71
firerescue9
Seriously! Not just that, the combination of the spoiler, lund sundvisor and lund bedthingy behind the cab, the rollpan and on the front of the truck he has the walmart brand foglights and a hulagirl on the dash board
Old Jan 14, 2013 | 11:03 PM
  #72
firerescue9
Went out for a stroll today, mud was frozen over, so i hit it and the truck sank. I thought for sure i was gonna get stuck but it didnt....just keept plowing thru pushing the ice out of the way. Was pretty deep too! the water was a little over the bottom of the door line!
Old Jan 18, 2013 | 02:32 PM
  #73
firerescue9
Update- Receiver hitch
Hey guys, so today i put on the receiver hitch that was on the '350 and threw it on mine. Had to take the ball off to work, and took some good ole' fashion muscle to get er done. heres some pics
Used some nice Grade 8 bolts, (have to get a couple more, i was short some)
So now, when i swap my axles out- i can tow a lottt more. I also going to box in some parts of the frame and make more crossmembers. I know ill never beable to make a 150 frame into a 350, but i can try!
I couldnt get third bolt drilled/in, the one farthest to the cab. so am going weld the brackets to the frame as well for added support. Ill try to get some more pics of what i mean in a lil bit
Old Jan 18, 2013 | 03:18 PM
  #74
Fastback460
The hitch looks good man. I like those backup lights you mounted under the bumper too.
Old Jan 20, 2013 | 09:34 PM
  #75
firerescue9
So i found my old grille in the garage today. pulled off the 'ole blue oval. i wanted to see what it would like on the billet grille so i taped it up to see.
What do you guys think??? I dont know if i like it or not.....and of course the girlfriend is indecisive so shes no help either lol
