Project Rednecktified
Old May 17, 2017 | 07:38 AM
  #316
meatloaf_CC's Avatar
meatloaf_CC
Got halfway done drilling and tapping my holes, then realized I don't have a drill bit for 9/16-18 tap (33/64)! Ordered that, should be here Friday. Then I can finish up this fuel manifold this weekend.
Old May 22, 2017 | 09:02 AM
  #317
meatloaf_CC
Got the manifold finished and hooked up, and all the fuel lines plumbed. Had a few leaks when I turned the pump on around the banjo bolts, but tightened them up and she's good to go.
Return lines on the right, pressure lines on the left. Gauge is reading 45 psi, which is correct supply pressure from the FASS pump. I'll probably keep the gauge mounted permanent.
Air filter is also mounted. Had to move the horn back ~1.5", but it fits pretty good. I'll probably build a shield around the turbo to help keep heat away from the air intake. Cold air=dense air=more power!
Old May 22, 2017 | 09:08 AM
  #318
meatloaf_CC
Oh, forgot to mention....IT RUNS!!!
Here's the first start. I'll post some more vids of it running. Getting a driveshaft built today, should be driving around the neighborhood next weekend!
Old May 22, 2017 | 11:02 AM
  #319
somethingclever's Avatar
somethingclever
congrats!!!
Old May 22, 2017 | 11:52 AM
  #320
vicp21's Avatar
vicp21
woohoo awesome!
Old May 22, 2017 | 12:00 PM
  #321
xringonly's Avatar
xringonly
Excellent! Nothin like hearing it run to provide inspiration
Old May 22, 2017 | 12:14 PM
  #322
co425's Avatar
co425
Congratulations! And very nice manifold sir.
Old May 22, 2017 | 12:52 PM
  #323
jakeharp's Avatar
jakeharp
Dam
That's Bad A$s, and the reward of a first start is priceless.....
Old May 23, 2017 | 02:42 PM
  #324
emeraldcoupe's Avatar
emeraldcoupe
nice! someone around here has the twin to your landcruiser.
Old May 24, 2017 | 10:38 AM
  #325
Aaron-71's Avatar
Aaron-71
Congrats! That's huge news for this build. Glad to hear it's not far away from rolling too
Old May 25, 2017 | 01:40 PM
  #326
ChaseTruck754's Avatar
ChaseTruck754
Awesome to hear it run! A bit jealous for sure!
Old May 26, 2017 | 10:55 PM
  #327
reuben78's Avatar
reuben78
Nice work. The perseverance is rewarded with a kick *** running truck!
Old Jun 1, 2017 | 08:14 AM
  #328
meatloaf_CC
Thats going in the garage once the truck is out! Big plans...
Old Jun 1, 2017 | 08:23 AM
  #329
meatloaf_CC
Took her for a spin over the weekend! Around the neighborhood. Everything seems to work good. Now just gotta button up all the wiring and loose ends so I can get it on the road!
Found these in the driveway today! 325/65-18 (~35") Goodyear Wrangler Duratracs. Tires I have on it are bald 37's. The 35's will fit much better, and look better I think.
Old Jun 1, 2017 | 09:44 AM
  #330
1KILLERZ's Avatar
1KILLERZ
Plus give you a little more head room. I cringed on the first video. I was "holy shiite! Is he going to make it out without scraping?!"
Looks great. Very jealous.
