Intercooler installation
Old Aug 26, 2012 | 08:01 PM
  #76
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
Originally Posted by therifleman556
Your just full of cool links ain't ya bud? Reps for you man.
6.0 IC looks doable. Might rig up a pressure tester and go check 'er out.
LOL. thanks man. more like good timing. i have psn up right now and that thread was up near the top of the obs section over there. if you do a search over there for the 6.0L IC installs there is a bunch more info i am sure. there are a couple guys on here that did a 60L IC as well.
Old Aug 26, 2012 | 08:47 PM
  #77
NMB2's Avatar
NMB2
Originally Posted by '94IDITurbo7.3
the 7.3's never had plastic tanks. the 6.0L's did.......
Sorry to burst your bubble....
but thats wrong. 7.3's did come with plastic tanks.
Old Aug 26, 2012 | 09:00 PM
  #78
therifleman556's Avatar
therifleman556
PART #2C3Z6K775AA
He said he pulled it out of a 7.3 to keep as a spare but then sold his truck and got a 6.0
Old Aug 26, 2012 | 11:02 PM
  #79
RacinNdrummin's Avatar
RacinNdrummin
Late 7.3's had plastic tanks... There might be an alloy tank here and there through the late 7.3's to deplete the stock ford had, but the later ones had plastic tanks... As long as your not planning to put out more boost than NMB2, or even I... Youll be fine with a 6.0 cooler...
Old Aug 27, 2012 | 01:31 AM
  #80
NMB2's Avatar
NMB2
Only thing I have to say about using a 6.0 cooler is this.
Reading the guys who swapped from 7.3 to 6.0 cooler, said it was not worth the labor. Take it for what its worth, but that is why I used a 7.3 cooler.
Old Aug 27, 2012 | 08:10 PM
  #81
91dirtydiesel's Avatar
91dirtydiesel
Well after a 600mi round trip, I got 16.9mpg...going over 2 major passes (Snoqualmie and vantage) and battling some tough winds in eastern WA. I averaged about 75-80mph 2400ish rpm's, 675egt flat 850egt on passes, 6-9psi of boost average, coolant temps highest I saw was 220* going up that long vantage pass....8miles up it (about 10 total) one of the intake boots popped off...EGTs instantly went to 1050* and I had to down shift just to maintain 65....all in all, it did pretty good in the hot eastern wa weather
Old Aug 27, 2012 | 08:39 PM
  #82
therifleman556
That's awesome man.
Have you had it on the rollers since the IC install? I thought I read mention of a dyno day...
I'll probably pick up that cooler tommorow or the day after hopefully. Thinking of how to connect everything, and how to get a reliable connection to the charge pipes without ruining the turbo's ability to go back to non-intercooled should it (the turbo) ever get sold.
Would going with 2 to 2-1/2" charge pipes be a good idea? The idea in my head says going with a smaller diameter charge pipe would be less volume to fill and make any lag or pressure drop smaller.
The experts might debunk my thinking, however.
Old Aug 27, 2012 | 08:42 PM
  #83
91dirtydiesel
Dyno will be on Wednesday....
Old Aug 27, 2012 | 09:25 PM
  #84
Rxracer27's Avatar
Rxracer27
Very nice results, i plan to do an intercooler very soon.
Rob
Old Aug 28, 2012 | 04:03 PM
  #85
turtlemann14's Avatar
turtlemann14
smaller pipe less lag, but more pressure drop
Old Aug 30, 2012 | 09:33 PM
  #86
therifleman556
Racin'
Do you have any pictures of your bead roller set-up? I found pictures of cheap ones made from vise-grips but that looks like it could get old in a hurry. Picked up my IC tonight and in keeping with the cheapo theme, I'd like to use regular aluminized exhaust pipe. I'll have to price all options before pulling the trigger though.
03wr250f
18
Nov 9, 2020 11:40 PM
2horses
6.7L Power Stroke Diesel
84
Apr 20, 2016 09:27 PM
91dirtydiesel
306
May 20, 2014 11:26 PM
jchosler
15
Oct 26, 2011 04:53 PM
Deluxe06
18
Sep 20, 2010 09:01 AM
