Intercooler installation
Old Aug 11, 2012 | 09:20 PM
  #31
xcite's Avatar
xcite
pm sent to you
Old Aug 11, 2012 | 10:23 PM
  #32
88 Ford IDI's Avatar
88 Ford IDI
If you get that leak closed up, the before and after on the dyno will be pretty interesting. Is it the same turbo as before?
Old Aug 11, 2012 | 10:26 PM
  #33
91dirtydiesel's Avatar
91dirtydiesel
Yes same turbo
Old Aug 11, 2012 | 10:34 PM
  #34
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
xcite, how long do you wait after you apply the sealant till you drive the truck?
Old Aug 11, 2012 | 10:39 PM
  #35
xcite's Avatar
xcite
sent you a pm
Old Aug 11, 2012 | 11:28 PM
  #36
88 Ford IDI
Originally Posted by 91dirtydiesel
Yes same turbo
Nice. The results will be interesting for sure...
Old Aug 12, 2012 | 04:01 AM
  #37
Ford F834's Avatar
Ford F834
Which builder kit did you buy? they have quite a few 3" versions of the 'ultimate' kit with different radius bends and in different materials. I want to do this but don't have the knowhow or equipment to weld aluminum, stainless, etc., can you use the mild steel or will it rust out?
Also, is your CDR routed into the turbo? The Banks kit does this and I'm thinking it will foul the IC with oil. My PSD unit has some oil dripping out of it, and seems like I read that oil residue reduces heat exchange, and it's a good idea to dump the crank case vapors with a road draft tube and keep that crap out of your intercooler. Just wondering what other folks are doing with their CDR's when they intercool.
Old Aug 12, 2012 | 08:57 AM
  #38
turtlemann14's Avatar
turtlemann14
mild steel wire will rust out on stainless.
all you need to do is pick up a bottle of stainless gas and the wire for it.
and anything in the ic precept for water(anything that will evaporate fast) will cause it to not cool as well.
Old Aug 12, 2012 | 03:23 PM
  #39
91dirtydiesel
I'm using mild steel. I have CDR going through turbo. I've had RDT before and hated all the smoke u could see at a stop
Old Aug 13, 2012 | 11:01 PM
  #40
91dirtydiesel
got the uppipe sealed a bit better. 5th gear and i floor it..... cant get it to 1000* egt now....gets to 10 psi (slower than before) and the boot from the turbo compressor to charge pipe keeps popping off at 10 psi..........
how can i fix this? tried multiple times with different torques on the t-bolt clamp and no luck...scared the chit outta me when it happened the first time, loud POP!
Old Aug 13, 2012 | 11:21 PM
  #41
88 Ford IDI
Try using T-bolt style clamps if you don't have them already. They are better than worm drive. It should help a bit...
Old Aug 13, 2012 | 11:28 PM
  #42
91dirtydiesel
haha yea i know
Old Aug 13, 2012 | 11:42 PM
  #43
RacinNdrummin's Avatar
RacinNdrummin
Brandon, I can turn a bead on the end of the pipe for you, so the pipe doesnt pop off... The t-clamp alone wont do it...
Either that or you can run a weld bead... One of my pipes has a weld bead though, and sometimes it pops off at 20psi, even with a T-bar... The bead is the pro way to go...
Old Aug 13, 2012 | 11:49 PM
  #44
91dirtydiesel
I'll take ya up on that! Yea these outlests are dam near tapered inward....less than ideal for a boot
Old Aug 14, 2012 | 12:09 AM
  #45
Rxracer27's Avatar
Rxracer27
another home brew solution is to try putting some hair spray on both the inside of the coupler and on the turbo put it together when a little wet still tighten it up and let it dry up.
i have heard that one used in the DSM world
Rob
