Intercooler installation
Tell me about it! I do really want too! Just gotta find one for the right price and the time to do so
Made a temporary 3" intake while I wait on boot. I have an awful uppipe leak since I had to remove it, so boost/egt results not 100 percent accurate, but boost wasn't as high and EGTs seemed much lower today.
Seems to like the 4" intake tube better, up pipe still leaking but here are some numbers.
going up same big hill:
55mph, 5th gear
No IC, 7psi up the hill, hits 1000* by the top
IC, 3.5 psi up the hill, hit 850* by the top
Floored right now I only see 8psi (uppipe leak) but EGTs haven't got past 900 yet. Cruising boost on flat at 50 is only around 1.5-2psi. I need to hit the freeway. When I touch the inlet vs outlet pipes there is a noticable drop in temp. Pump I'm using is still maxxed out, and not sure on my timing.
55mph, 5th gear
welcome to the club known as "leaking up-pipe kills boost and makes truck sound like crap" club.
mine is kinda weird though. first gear hammering on it i will max out at 6psi, then i let off a little, it shifts into 2nd, pedal threw the floor and i can hit 9psi easy, then it hits 3rd and boost never touches 9psi again. seems like right now 2nd is my money gear for boost. IDK
Throttle response has dropped, but still feels like its pulling strong. Guess well see on the dyno next week (guess I don't need to worry about my head gaskets now LOL)
The uppipe? I've tried all the magical sealants and they all failed. I took pipes off, wire wheeled them spotless, applied on male ends, let them cure and no luck. My only luck has been let it be and wait for soot to seal it
are you sure they aren't moving causing it to re-break the seal?
one would Wonder if dumping a little oil in the manifolds or applying grease on the inside of the joint would cause the carbon to stick to it and seal it faster (also lugging it soon after applying the grease/oil).
i think if lugging it worked to seal it up then mine would be sealed up by now LOL. when my truck is in O/D i can make it look like i have a Cummins under the hood LOL.
This isnt rocket science here, there is no majic, it is not a band aid, it is what works. How do you think they seal up multi piece exhaust manifolds on the big rigs, they dont wait to let soot seal them up, the dot would love them for that.
If you really want to fix your problem fast get ahold of me, if you think I am full of it keep waiting for the soot to seal it or spend alot of money. If you need my number call NMB2 he has it.
