Climate Control
Old Jun 19, 2012 | 01:12 PM
scotty088's Avatar
scotty088
Climate Control
Having quirky issues with my climate control unit.When I change the air flow control from defrost to dash ducts or floor it doesn't always work.When I start the truck after it has been set on dash ducts It will be set on defrost.After changing it might take several minutes to change over.Or not at all.I have checked all the vacuum hoses no leaks detected.I'm stumped any ideas would be greatly appreciated.
Scotty
Old Jun 19, 2012 | 03:13 PM
sergbaja5t's Avatar
sergbaja5t
Keep looking for a vac leak @ the flapper valves.
Old Jun 19, 2012 | 08:44 PM
Bota's Avatar
Bota
I had this problem as well, i had accidently pulled the line off the valve right over the Passenger valve cover.
Old Jun 19, 2012 | 08:51 PM
spocky1187's Avatar
spocky1187
I had the same problem stuck in defrost had to replace te vacuum pump its an easy job
Old Jun 20, 2012 | 02:03 AM
Yahiko's Avatar
Yahiko
Get your hands on a vacuum gauge and see
how much how much you have and how fast it
leaks down.
Sean
Old Jun 20, 2012 | 02:58 PM
scotty088's Avatar
scotty088
Poking around under the hood I found a vacuum hose off at the heater hose valve.Plugged it in and low and behold the compressor shuts off now and holds steady 30 hg.vacuum.Thanks to all who responded,as usual your expertese is awesome
Scotty
Old Jun 20, 2012 | 03:37 PM
Yahiko's Avatar
Yahiko
Good to hear you got it fixed !
Sean
dievert
1997 - 2003 F150
Nov 18, 2011 05:31 PM
chayes01
Jun 17, 2009 08:39 AM
dfooch
Jun 20, 2008 08:40 AM
sting454
Oct 25, 2005 07:56 PM
llbcd
Mar 23, 2005 06:59 AM
