Sponsored by: Real Truck
Climate Control Problem...
Old Jun 19, 2008 | 09:58 PM
dfooch's Avatar
dfooch
I have a problem with my climate control system. It only blows the A/C through the defroster vents. It will not blow through the panel or floor vents. Right before this started, after turning on the truck, I heard a fluttering noise from behind the dash when all the air got redirected to the defroster ducts. A friend of mine said it is possibly a vacuum line not engaging the doors that redirect the air. Any quick suggestions/remedies to solve this problem? Anything I should look for under the dash? I really need to use my truck this weekend and would rather not lay it up at the dealership if I can fix it myself.
NOTE: This is occuring on the SD listed in my signature.
Thanks for any assistance
Dave
Old Jun 20, 2008 | 01:38 AM
drbalazo's Avatar
drbalazo
Most likely you have a vaccume leak somewhere
Old Jun 20, 2008 | 07:06 AM
projectSHO89's Avatar
projectSHO89
Either a vacuum leak as suggested or your vacuum pump is not running are the most likely reasons.
Manual or auto climate control?
Steve
Old Jun 20, 2008 | 07:42 AM
DAFBFD58's Avatar
DAFBFD58
Sounds like a vac leak. A good place to look is the lines to your hubs. You could have snagged them with something and slit one and now you have a leak.
Old Jun 20, 2008 | 08:40 AM
dfooch's Avatar
dfooch
Steve
I have the automatic climate control.
