A/C Help
Old Mar 22, 2005 | 09:37 PM
llbcd's Avatar
llbcd
A/C Help
Does anyone have a fix for this problem. 92 F-150 with a/c. Here is the problem for some unknown reason my a/c will quit blowing from the dash vents and begin blowing from the defroster vent on top of dash. This also happens if I run the vent setting for fresh air. ANy ideas?
Old Mar 22, 2005 | 10:18 PM
Domenico's Avatar
Domenico
llbcd, Little difficult to diagonse without checking the vehicle, but it sounds like a vacuum leak at the mode control switch or source, the mode control system will defualt to defrost in the event of a low vacuum level. do you get the same symptom if you are under load up a big hill?. Let me know
Regards, Domenico.
Old Mar 22, 2005 | 10:27 PM
llbcd's Avatar
llbcd
usually happens when i het bumps, can make it swithc back sometimes by tapping on dash
Old Mar 22, 2005 | 11:11 PM
Domenico's Avatar
Domenico
Sounds like a loose vacuum line connector / fualty control unit or broken vacuum line, remove the heater control bezel and the screws that hold in the heater control unit, try wiggling the hoses, control ***** and vacuum line connectors to agrivate the problem. If no luck there do the same to the vacuum supply line and related vacuum motor/connectors.
Regards, Domenico..
Old Mar 23, 2005 | 06:59 AM
firstonraceday's Avatar
firstonraceday
There is small diameter white plastic vacuum tubing under the hood that runs to the vacuum motor at the blower housing (passenger side under the hood). On my '93, after a few minutes driving on max, the air flow would be diverted to defrost and not come back to the dash registers. When I looked under the hood, I noticed the above mentioned tubing had deteriorated and was disintegrating. I cut out the damaged section and slipped a piece of rubber vacuum hose over the remaining ends of the plastic. Been working fine since. Hope this helps.
