Sponsored by: Real Truck
Climate control on dash dead
Old Oct 23, 2005 | 04:57 PM
sting454's Avatar
sting454
Red face Climate control on dash dead
I was wondering if anyone else had this same problem..This is the 2nd time this happened...Automatic climate control dead..nothing works..Checked fuses ok...Now i have no heat/ or a/c...
Help!!!
Old Oct 23, 2005 | 07:09 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Thread moved
Old Oct 25, 2005 | 06:44 AM
tileflyer's Avatar
tileflyer
I am taking my truck in tomorrow for the same thing. It will be dead and then get back in the truck and it will work fine. I will post what they do to fix the problem. It must be a software problem??
Old Oct 25, 2005 | 10:07 AM
Fat Diesel's Avatar
Fat Diesel
It might be a vacuum problem. Check the vacuum lines under the dash that go through the passenger side firewall. It's the intermittent part that is a pain.
Old Oct 25, 2005 | 02:56 PM
sting454's Avatar
sting454
as i recall mine stopped working right after i was playing with my shift on the fly 4 wheel drive control..I believe that works on vacuum also
Old Oct 25, 2005 | 07:11 PM
BigF350's Avatar
BigF350
FTE Emeritus
Yes it does.
I think you may have discovered something. Good luck!
Old Oct 25, 2005 | 07:56 PM
gmccarver's Avatar
gmccarver
Have been having the same problems over this past year. Mine would quite for as little as a few minutes and /or as long as a hour or so. During each "blackout" I would try switching on/off each electrical item, various combinations looking for anything. Was fortunate enough to make it to the dealership during one of the many "blackouts". Service writer witnessed the problem, paged for tech to come up front to test the unit. Before tech could arrive, it started back working. Dealer did write up on service order, but until something is identified as "broke", dealer will not start "guess" replacing parts.
