Problem with A/C
Old Jun 17, 2009 | 08:07 AM
chayes01's Avatar
chayes01
Problem with A/C
I did the A/C bypass valve at the same time I had my dash disassembled and now I have a problem. I put the vacuum T in the redline behind the glovebox and now my A/C (which does work) comes out of the defrost only. When I had the dash apart I had to remove the climate control panel. The vacuum connection will only go on one way so I assume that I got it on correctly. Does anyone have an idea of a fix before I tear the dash apart again?
Old Jun 17, 2009 | 08:09 AM
Kwikkordead's Avatar
Kwikkordead
You have to find the source of the vacuum leak and repair it.
Climate control defaults to defrost if you lose vacuum.
Old Jun 17, 2009 | 08:39 AM
vettdvr's Avatar
vettdvr
You are correct I agree vacuum leak must be fixed.
