Minnesota Chapter Join Chapter, Leader: fordpower88
June B.S. Thread
Old Jun 26, 2012 | 10:14 PM
  #1561
msmenne17's Avatar
msmenne17
Good evening everyone!
Baseball night for Andrew. He's doing awesome and has come a LONG way since his first game.
It was his birthday, so we went and had some DQ awesomeness after the game.
Dale ... I'll speak for the Ex as well ... NOT. I don't want an Excursion. I do want another CC F250/F350 though. It's gonna be a while I think.
Old Jun 26, 2012 | 10:25 PM
  #1562
DieselCamper01's Avatar
DieselCamper01
Sounds like a nice evening Michael.
Old Jun 26, 2012 | 10:26 PM
  #1563
Devious Delight's Avatar
Devious Delight
Ok, questions, because either google is failing me, or I suck at using it...
1.doing the front brakes on my '77, figured I should look at the wheel bearings since I'm going to have them nearly apart. the haynes manual says to wash the bearings in part solvent and then repack them. Thoughts on necessity of washing out the old grease?
2. What grease to use?
3. One of the the threads I read mentioned a special socket to remove the axle nut. supposedly costs $50... ideas around it?
edit:
special socket for this OTC #7158 or similar. and yes I realize (now) it says $26 on amazon... anyone want to lend me one?
Old Jun 26, 2012 | 10:33 PM
  #1564
msmenne17's Avatar
msmenne17
1) If you're going to bother doing it at all, do it right. I use brake cleaner to wash them out.
2) bearing grease rated for Ford. Not sure if it really matters.
3) Rent it from a parts store. Advance Auto rents a kit that works for multiple vehicles
Old Jun 26, 2012 | 10:36 PM
  #1565
dlibson's Avatar
dlibson
The socket is one with 4 little nubs that push in the lock ring IIRC.
For the bearings, just rinse with brake clean and work in new grease and you'll be fine. Get wheel bearing grease...
Old Jun 26, 2012 | 10:38 PM
  #1566
DieselCamper01
I have only had one bearing on a trailer fail in my years of driving. All I do is pump new grease in between each roller with a special attachment on the grease gun. Looks similar to a needle for pumping up a basketball or football.
Old Jun 26, 2012 | 10:42 PM
  #1567
Devious Delight
never done one before, just crossed my mind. will check on renting one.
correct on the socket. will use brake clean.
  #1568
dlibson's Avatar
dlibson
I'm sure I have the one you need Dustin.
  #1569
msmenne17's Avatar
msmenne17
Not sure what Gert looks like, but with mine, I got confused between the 4WD hub and the spindle nut at first. It was the first time I had done it and hadn't seen any pictures of it.
On mine, there is a spring clip that holds the hub in. Take the spring clip out and the hub slides out to expose the spindle nut. The nut comes out with the tool. It would be really hard to get to without the spindle nut socket. Remove the spindle nut and the hub and bearing assembly slides off.
YMMV as this was my 1996.
Old Jun 26, 2012 | 10:43 PM
  #1570
msmenne17's Avatar
msmenne17
Time to turn in. Good night all!!
Old Jun 26, 2012 | 10:44 PM
  #1571
Devious Delight
I can pack them, I think I remember how... It's been awhile...
Old Jun 26, 2012 | 10:45 PM
  #1572
DieselCamper01
It is well past my bed time so I am going to sign off. Have a good night guys.
Old Jun 26, 2012 | 10:48 PM
  #1573
Devious Delight
AWESOME, can I swing over friday or saturday AM?
I'm not sure either, but I'll find out when I get it apart. I don't want to try to run one down with it all apart. Looking at the ($hoasdf;jlaksdf;aklsj) haynes manual, It appears that I need one.
Since I can't find a DIY for it, I'm going to create one. I'm sure it'd help all the newbs and people that have never done one before.
Old Jun 26, 2012 | 10:51 PM
  #1574
Devious Delight
since I rarely post at night, I think I'll lock up.
Tom, you know where the key is...
Old Jun 26, 2012 | 10:52 PM
  #1575
dlibson's Avatar
dlibson
I'm leaving for camping till Wednesday Friday at noon Dustin. So before or after...
I'm heading to bed as well. Goodnight all!
