Hey Mike! That sucks you are not busy. Hope things turn around and get busy for you.
Just to make sure..........you don't want to roll the bearing in the grease. You put a slab of grease on the palm of your hand and then take your other hand and pound the bearing on the palm of your hand with the grease on it driving the grease into the bearing.
Grease in your palm? Pounding? What the heck are you giving him tips on doing? This is a family friendly site you know...LOL
I knew you would comment on that Jay!! LOL I was laughing as I was typing just waiting for someone to comment on it! Besides as CL I can say what I want!
Excursion update. Crawled under it to see if the fuel pump was working. It comes on but doesn't shut off, keeps running and has a weird sound like air mixed in it. Gave it some shots of either and it speeds up cranking over but wont start. If pump was bad bad not putting out enough pressure or any at all so no fuel into cylinders, should it still run for a quick bit on either or not?
