Build Thread: '49 F321
Old Jun 18, 2018 | 08:27 PM
  #556
52 Ford F1's Avatar
52 Ford F1
Saved some bucks and they never seam to do it the way you want them to on the first try either... keep it up
Old Jun 20, 2018 | 06:52 PM
  #557
yamagrant's Avatar
yamagrant
Where did you get the pipe from? Lookin Good!
Old Jun 22, 2018 | 02:46 PM
  #558
Jeff and Nicolle's Avatar
Jeff and Nicolle
Found it through Amazon. Prime customer. Free shipping!
Old Jun 22, 2018 | 03:06 PM
  #559
yamagrant's Avatar
yamagrant
Thanks. I'll look into it.
Old Jun 22, 2018 | 10:47 PM
  #560
Jeff and Nicolle
Aluminized Steel 2.50" Diameter Universal U-Fit 16 Pieces Dual Exhaust Pipe Kit Mandrel Bent Tube Tubing Tail Pipe Tailpipe System https://www.amazon.com/dp/B01LXQWCWA?ref=yo_pop_ma_swf
I didn't know you wanted specifics my friend!
Above is what I bought. Real happy with the quality!
Old Sep 12, 2018 | 09:16 PM
  #561
Jeff and Nicolle
So I got the exhaust turned out in front of the back tires for now. I will deal with the rear exit later...I wasn't quite satisfied with what I had. And I really want to work on getting it running before it gets bitterly cold. Time is flying! Work keeps me under the thumb...and I don't like fighting mosquitos...they are horrible here!
Old Sep 12, 2018 | 09:19 PM
  #562
Jeff and Nicolle
I got this 2003 Suburban 3rd row seat and started to work out how to mount it. I was able to use the original slide brackets from the '49. I am happy with how it turned out!
Old Sep 12, 2018 | 09:22 PM
  #563
Jeff and Nicolle
I had some 5\8" bar stock and had to turn it down a bit where it goes into the seat clamps.
Old Sep 12, 2018 | 09:25 PM
  #564
Jeff and Nicolle
Then I used some 1 1\4" angle iron.
Old Sep 12, 2018 | 09:27 PM
  #565
Jeff and Nicolle
Side view.
Old Sep 12, 2018 | 09:28 PM
  #566
Jeff and Nicolle
Drilled holes into the angle and stuck the rod through.
Old Sep 12, 2018 | 09:30 PM
  #567
Jeff and Nicolle
Lined up the '49 seat bracket. Center punched and drilled more holes.
Old Sep 12, 2018 | 09:37 PM
  #568
Jeff and Nicolle
I missed pictures of the completed adapter, but I bolted it up, then tack welded the rods to the angle iron. Then removed the factory slide assembly, cut the rods to length, welded the angle iron and rods together. Ground down the excess, cleaned, primed, and painted. Reassembled the package deal and bolted it to the floor!
Old Sep 12, 2018 | 09:41 PM
  #569
Jeff and Nicolle
It will fold down for storage access, pull another lever and raise up for access under the seat, and yet another lever allows me to remove the entire seat from the cab if needed. However there may be some interference with the steering wheel, but I'm okay with that.
Old Sep 12, 2018 | 09:45 PM
  #570
Jeff and Nicolle
I love the built in seat belts and the headrest location. Also the tan looks good with the green. This turned out easier and better than I expected! About time!
