The TJBEGGS E fuel thread! ALMOST COMPELTE!
Old Dec 17, 2012 | 08:03 AM
  #91
tshrager's Avatar
tshrager
Originally Posted by tjbeggs
What you don't know is that the reason it took so long to finish this is that I have been writing a new suspense novel......
A new thriller from the creative mind of Tim. Where the protagonist battles the want to mod his OBS vs the will of his wife...in theaters summer 2013.
Old Dec 17, 2012 | 08:18 AM
  #92
Awitte58's Avatar
Awitte58
He could write a novel about the stuff that goes on FTE! lol
He probably was making this thread a cliffhanger and described it in his writings.
Old Feb 16, 2013 | 09:09 PM
  #93
dougbrown's Avatar
dougbrown
Update, I have been reading a few different E fuel threads. I came across this.
Holley Performance Products Fuel Pump Safety Pressure Switch 12-810
A racer budy was telling me about it on his race car. I was thinking why wouldnt it work on the truck? what do u guys think. If u read the instructions it tells u how it works. What u guys think!
Old Feb 17, 2013 | 06:01 AM
  #94
427 fordman's Avatar
427 fordman
This is the one that comes with the strictly diesel kit. If you go to their website, it's under half that price. I put their whole wiring harness in.
Old Feb 17, 2013 | 12:19 PM
  #95
Awitte58's Avatar
Awitte58
Does that entire wiring harness come with the oil pressure switch and the pump controller?
What about some sort of inertia switch?
Old Feb 17, 2013 | 12:28 PM
  #96
tshrager's Avatar
tshrager
That's the kit I was telling you about. It comes with everything for around 150 IIRC. It's what I'll be going with.
Old Feb 17, 2013 | 03:05 PM
  #97
dougbrown's Avatar
dougbrown
What the inertia switch work? If you are in an accident and loose oil psi it will till the fuel pump.
Old Jun 5, 2013 | 09:58 PM
  #98
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
with the dual inlets on these filter heads, can you run two feed lines into a filter head an then one output? will there be any issues with one input back feeding the other input line or anything like that?
Old Jun 6, 2013 | 06:17 AM
  #99
tjbeggs's Avatar
tjbeggs
Yes you can run dual in and dual out if desired. Feedback will depend. The fuel will take the path of least resistance. if you are pumping into it will not likely be an issue. If you are sucking in, say from two different tanks, one will empty before the other.
Old Jun 6, 2013 | 08:17 AM
  #100
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Tim is ALIVE!. Glad to see you over here amigo.
Old Jun 6, 2013 | 09:09 AM
  #101
oldbird1965's Avatar
oldbird1965
x2 on that!
Old Jun 6, 2013 | 10:03 PM
  #102
'94IDITurbo7.3
thank you
Old Jun 11, 2013 | 07:14 PM
  #103
diesel&coffee's Avatar
diesel&coffee
Do you think a 3/8 fitting would fit in the rear of heads.. ie: 1/8 pipe nipple to maybe 3/8 straight - 3/8 90*.. or 3/8 fitting after 90* ??? ... Basically I may run 3/8 from pump on.. Using a FASS 80 PSI variable pump..
Old Jun 11, 2013 | 09:45 PM
  #104
ReBilld's Avatar
ReBilld
The stock fittings in the back of the heads will accept 5/16" steel line and a compression nut and feral. The stock lines are 1/4", so 5/16" is an upgrade. I really don't see the need to run 3/8" to each head. This how I did mine....
Old Jun 11, 2013 | 10:14 PM
  #105
nomad221's Avatar
nomad221
Nice work bending the lines Bill, very clean install. With the motor installed in the bay, is the passenger side line compression nut accessible ?
