I tore into the brakes and OMG! Someone ran it with no brake pads for a while at some point. I removed the pads that were in there now and found the piston to be melted from a little metal on metal grindage. I just hope the new pads will fit, otherwise time to modify.
Jay, I am not sure I like this whole sledding thing anymore. Seems like a boat to me, just a money sucker. lol
Looks like that is where the shock mounts also so there should at least be a pair of small collars/spacers between the wheels and the shock. I almost garauntee there is a snap ring on each of those wheeles to keep them in place also. Should be able to hold the opposite side with a vice grips like Jim mentioned (in theory).
Make sure the slack is out of the back side of the chain by turning the secondary clutch a counter clockwise(forward). To set chain tension, finger tighten the tensioner bolt and back off 1/4 turn.
Looks like you are also missing a nut that holds the chain case to the chassis, better get one on there, should be 3/8"(use a nylock nut)
That seems way loose. I tightened with a wrench so the chain moved slightly by finger (like on a bike). I guess I need to adjust again. Good thing I am out of gear oil or I would have a mess.
Yes I can get a pic. I don't mind working on them if they cooperated. I don't like stubborn bolts and broken parts. I guess I like regular maint. type of stuff oh, and modifying!
Hey Tom .. next time your coming down to Kato land .. could you bring your AE with? I'd like to see if I can figure out what the slippage is in my tranny before I start ordering parts.
I'm not as convinced on the TC as I was before, but still think it's a strong candidate. I drove it quite a bit this last week w/o Overdrive and haven't tripped a code yet. OD will trip it within 20 miles or less.
Will do Michael, not sure when that will be but I will let you know......
