Well ... I was feeling better until about 1/2 hour ago. I ended up having to drive to Kato to pick up kids as Katie was running late. The plan was to drop them off at the house, then come home and veg/sleep. I ended up bringing all three home with me so they could go to bed at a reasonable time and Katie could do some work on the house.
It is going to be a NyQuil night. I figure a good night's sleep and I should hopefully be feeling better tomorrow.
If you think so. Well if you want, I am off the 16th, 17th and 18th. Otherwise home on weekends by 1600 or 4:00 for you people with broken clocks. I can wait till the GTG too.
I will let you know what I can make work out Cory.
Originally Posted by HP junkie
Hey Jay, I think this is the part the wheel is connected to.
We can get that out. Just need to take a lot of bolts off.
I dont know if I will do that, I might wing it. I don't know how much money I want to sink into it.
Should be able to pick up a used caliper setup off craigslist pretty cheap.
Originally Posted by Jbotto
Evening guys! You all are quite chatty tonight! Looks like some fun projects out there! I had the first day of class again today which started at 8 and was done at noon. I can live with that schedule for mondays, this semester!
Hey Jake. Glad the Monday schedule is an easy one. Helps ease into the new week.
Originally Posted by dlibson
Evening all!!!!
Jay, the goose and t stories are long ones. Probably best for a GTG. There are some pics to go with the goose story too.
Don't forget when we are all at Cory's on the 28th.
Originally Posted by mndiesel
Things are good Dave. How was bowling?
What is your new AV Tom?
Originally Posted by msmenne17
Evening everyone!!
Welllllllllllll................................... .....it all depends on the clutch side. There is a collar on the inside of the tunnel that you need to get the set screws loose. After that it is all pretty easy. Other than wrestling the track and suspension back in...
I was just reading about doing slides when the windows are small. With a sharp razor knife you can enlarge a window on one side then rotate the track 90* to 180* so the other side isn't right by the other and you will be good to go. Doesn't matter this time but for later it will be nice.
