Trans. Temperature?
Old Nov 27, 2011 | 06:50 PM
  #46
SpringerPop's Avatar
SpringerPop
That would be a great idea, but do we know if he wants to put up with the "grief"?
I sure wouldn't....
Pop
Old Nov 27, 2011 | 07:45 PM
  #47
White 99's Avatar
White 99
Originally Posted by Mark Kovalsky
That can happen, but only well below 0°F. And we found that if the bypass opened from cold, thick ATF, it didn't close again until the ambient got quite a bit warmer. Once the cooler plugged from thick ATF it doesn't matter how hot the trans gets it won't force the cold oil out of the cooler.
Thanks for the explanation. I appriciate your help here.
Old Nov 27, 2011 | 08:42 PM
  #48
RolnCl's Avatar
RolnCl
Yes, thank you for all the posts. That was very helpful.
Ben
Old Nov 27, 2011 | 09:07 PM
  #49
Stewart_H's Avatar
Stewart_H
I sure wouldn't....
Pop
He already does, if you ask me!
Stewart
Old Nov 27, 2011 | 09:17 PM
  #50
MikeSDK's Avatar
MikeSDK
Originally Posted by RedBoat
I added a true cool tranny cooler to mine and tranny temps run about 70deg above ambient and around 80-90 above ambient towing.
Same with me. I also have a trans-go. Just towed a 7500 lb travel trailer from Destin, fl to Nashville. 62* ambient, 160* towing hard uphill all the way.
Old Nov 28, 2011 | 02:05 AM
  #51
Robert6401's Avatar
Robert6401
Stewart
There are a few people on here who, moderator or not, have built such a reliable reputation that the expectations for what comes across their keyboard are so high that they may as well be our Powerstroke Messiah. I could start a list of names, but I won't. I guess what I'm getting at is that I agree with Stewart in that anytime there is a transmission thread we all refer the poster to Mark because he is our transmission expert. So would the aggravation of moderating the transmission forum really be any greater?
Old Dec 4, 2011 | 03:21 PM
  #52
sand_fiend's Avatar
sand_fiend
Every time i think i have read everything about our trucks, Something new to me comes along.. Thanks guys...
Old Jan 23, 2012 | 07:02 PM
  #53
cutlass's Avatar
cutlass
This is a great thread and I really appreciate you passing down your knowledge of transmission temp. to us Mark!
I have to ask about the use of transmission filters. I've been told that it's not a good idea to use a transmission filter because it actually lowers the transmission pressure and can actually cause damage to the transmission since it's not operating at the proper pressure.
Hopefully, Mark or someone else will be able to confirm or debunk this theory.
Thanks,
Drake
Old Jan 24, 2012 | 07:04 AM
  #54
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If you use a filter that has a bypass when it plugs it should be fine. If the bypass on the side of the transmission is removed I would NEVER install a filter in the line. If the filter gets restricted it will cut pressure to rear lube and the trans fails. If the bypass is in place and the filter gets restricted the bypass opens, the trans gets lube, but gets hot. You can stop before melting the transmission. Without the bypass the trans dies before you get any indication that something isn't right.
Old Jan 24, 2012 | 08:21 AM
  #55
outdoormaniac's Avatar
outdoormaniac
Mark,
last summer i had the local performance shop put in a new NADP Heavy Hauler transmission in my 02 F-350. The mechanic didnt put the temperature probe back in the tranny after the re/re and when i asked him, his answer was that where the probe was located on the drivers side just above the trans pan, it doesnt give you a 100% accurate reading. His suggestion was that i should look for a deep sump pan that is tapped to have the probe in the pan, and this will give me a more accurate reading. Id really like to hear your opinion on this.
I use the truck heavy, it has a 8'6"x9' steel deck with a full tidy tank most of the time and a 30' dually gooseneck with 10 000 lbs to 20 000 lbs on it. Usually run 30 000 + gross when hauling hay etc and on some tough hills. I want to make sure im monitoring my vitals correctly.
Cheers!
Old Jan 24, 2012 | 08:35 AM
  #56
mueckster's Avatar
mueckster
The PCM uses temp readings from the TFT sensor in the Solenoid Valve Body. These readings can be 15*-20* higher than those found from the Pressure Test port on the side of the trans. So in a sense, he is correct. I have a trans temp gauge sender in the test port and also monitor the TFT sensor readings with my Aeroforce Interceptor Scangauge. I tend to follow the higher reading and have my annunciator set to alert me if the temp rises above 200*. This is not a "danger zone" setting, but simply to let me know if things are heating up.
Old Jan 24, 2012 | 09:39 AM
  #57
Mark Kovalsky
Deep sump pans are good for making the bottom of the truck look nice. That's the only benefit that I can come up with. It will not help your cooling at all.
From my testing the pressure port gives a more accurate reading than any place in the pan. The pan is the coolest part of the transmission. Depending on where you place the probe in the pan you can be 15 degrees or so different from another place in the pan, either higher or lower.
Sometimes that's true, sometimes the PCM sensor is lower than the pressure port temperature. There's no good way to determine which one is higher or lower.
I do not recommend putting the sensor in the pan. If you want to know the internal temperature of the transmission the best place to do that is where the stock temp sensor is located, on the solenoid body. The next best place is the pressure port. The worst place to put it is in the pan.
Old Jan 24, 2012 | 09:51 AM
  #58
outdoormaniac
Thanks Mark. It makes sense that you would want to monitor the hottest area of the tranny. Not only that, but the bottom of my truck is always muddy....it doesnt need to be pretty!
Cheers
coachvassar
2009 - 2014 F150
May 16, 2017 11:03 PM
mark224
Dec 9, 2016 09:29 PM
mustang9701
Jan 2, 2013 04:53 PM
dinty01
Jan 26, 2005 11:37 PM
AV3Fire
Sep 7, 2004 06:24 PM
