Trans. Temperature?
The cold side of the radiator can be anywhere from 15°F to more than 150°F degrees cooler than the coolant coming out of the thermostat. If the truck is running unloaded in a below zero ambient temperature the cold side of the radiator, where the trans cooler is located, is just about ambient. So the ATF cooler is seeing coolant around it that is at -40°F. How would that warm the ATF? It's still cooling the ATF.
Not in my experience. Coolant temperature always has risen quicker. It's cooling an area heated by combustion. That gets a lot hotter than anything in a transmission ever gets. I've run vehicles from +121°F to -48°F and I have never seen a transmission warm up faster than an engine.
Also 170°F. Usually when towing heavy it will get hotter than that, but 170°F would be ideal.
the answer to your question is yes.just like the engine,the auto trans has a minimum ideal operating temp as well.this temp is 150 degree's.
below 150 degree's and the efficiency of the trans suffers.this is a large reason for reduced fuel economy in winter months.
you can add an external oil cooler t-stat bypass yourself,fairly economically.i did this with mine,and it really helps getting the temps up quicker.
Transmission Oil
https://www.ford-trucks.com/forums/7...l#post10773358
Transmission Oil
im sure an auto trans works best at its minimum temp of 150 (preferably 175) regardless of oil type.but as we know synthetics flow soooooo much easier than dino juice when cold.
if i ran synthetic trans fluid (i did debate it) i personally would still try to achieve ideal trans temps (partly why i didn't go synthetic.)
however the advantage is,that while getting up to temps,the efficiency of the trans should still be decent.
as far as heat goes,check the flash point,it's likely also much better than dino,
again though,the clutch material in the trans etc.is only designed for so much heat.so again,if i ran synthetic in the trans,id still aim for the ideal 175F.
perhaps someone knows otherwise,but i wouldn't blindly run my trans higher in temps simply because the oil could take it.id still be concerned with the rest of the trans.
so in short,unless someone knows otherwise.id stick with the same chart myself if i ran synthetic oil.
Transmission Oil
During the winter months my trans guage usually doesnt move and it goes as low as 100 degrees.
id like to know what this is.
at any rate,the radiators section for the auto cooler,does in fact raise trans temps.
have you ever run your engine a little on the warm side with an auto trans? if you have,you'll notice the trans temp also increase (even without extra load.let's say with a failing water pump/coolant fan for example.)
the coolant flowing though the radiator is very warm of course (around 200F for diesels,we'll say roughly.) this heat of the rad does indeed transfer over to the ATF fluid.im surprised to hear you say otherwise really.
clearly im misunderstanding this cooler type that was added in 2000,and im interested to learn more about it.
the saying that you can expect to see such and such a temp depending on the outside temp is true.but this doesn't mean we can't increase the efficiency either via;
a.electric fan on the cooler (to help keep around 175 for all towing conditions)
b.adding a t-sat to help bring temps to the ideal trans operating temp when running empty/winter months.
synthetics of course will be much more efficient over a wider range of temps than dino oil.your likely setup pretty good with the synthetic,but blocking off your external cooler during winter months (when empty) to try and maintain 175 couldn't hurt either.i personally would still add an external t-stat.simply because they're pretty affordable,easy to install,and having a temp year round closer to 175F is never a bad thing.
one would think running ATF at thicker viscosity (too low of temps) where the fluid is not designed to work ideally,wouldn't be the healthiest practice for the trans either ya know?
On my truck it came without the Oil to Water cooler in the radiator. The transmission overheated and was replaced under warrantee. When they replaced the trans they also replaced the radiator with the new style. I think that Ford realised they had made a mistake by eliminating the raditor cooler on the early 99's.
