Sponsored by: Real Truck
Transmission Temp.
Old Dec 9, 2016 | 04:26 PM
mark224's Avatar
mark224
Transmission Temp.
I've never had a vehicle with a Transmission Temperature gauge before and was just wondering what the normal running temp. is for a 2016 F250 6.2l 6 speed transmission. Mine seems to be operating around 205 degrees F at max no load and 30 degrees outside.
Old Dec 9, 2016 | 04:50 PM
Cwsocks's Avatar
Cwsocks
That seems right, I also have a 2016 6.2L. Usually between 199 and 205. When towing in the mountains during the summer I have hit 220.
Old Dec 9, 2016 | 05:00 PM
Rob89's Avatar
Rob89
My 2016 6.2 drives around in South Florida heat and humidity and the highest I've ever seen it is 207 while pulling 5,000 pounds in stop and go traffic. normal unloaded Temps range between 196 and 201.
Old Dec 9, 2016 | 08:23 PM
cyncwby's Avatar
cyncwby
The 6 speed trans has an internal thermostat that keeps the trans in the 200-205 deg. range, my '16 does the same thing.....normal .
Old Dec 9, 2016 | 09:29 PM
mark224's Avatar
mark224
Thanks only have 1500 miles on it knew it wasn't high but was curious what it should be.
st.rodder2
Sep 1, 2016 09:25 AM
Three30Eighr
Feb 5, 2016 08:33 PM
jyarosz
2009 - 2014 F150
Apr 8, 2014 08:15 PM
RolnCl
57
Jan 24, 2012 09:51 AM
AV3Fire
Sep 7, 2004 06:24 PM
