In winter months driving empty which is what I usually do, from what Im reading and correct me if Im wrong I should still be trying to get my trans up to 170-175 degrees?
It's not likely that you can do that. I didn't say you need to get it to that temperature, I said that's the temperature that is ideal for the trans.
Originally Posted by FORDF250HDXLT
the radiator section for the trans was added in 2000? what do you mean by this? this has been the factory way to cool a trans for years prior to 2000.
Starting in 1999 there was only an air to oil transmission cooler out in front of the radiator. There was no radiator section for the transmission. Ford realized this was a problem and added it back in mid year 2000.
at any rate,the radiators section for the auto cooler,does in fact raise trans temps.
No, it does not. I've measured coolant and ATF temperatures in and out of the radiator, and also inside the radiator around the transmission cooler. I measured these with loaded and unloaded vehicles from -48°F to +121°F and I NEVER found a condition where it was even close to the radiator warming the transmission. The ATF was always quite a bit hotter than the coolant around the cooler. You can't heat the ATF when the coolant is at a lower temperature than the ATF.
have you ever run your engine a little on the warm side with an auto trans? if you have,you'll notice the trans temp also increase (even without extra load.let's say with a failing water pump/coolant fan for example.)
the coolant flowing though the radiator is very warm of course (around 200F for diesels,we'll say roughly.) this heat of the rad does indeed transfer over to the ATF fluid.im surprised to hear you say otherwise really.
Yes, if the engine is overheating the radiator is not able to cool the ATF as efficiently and the transmission temperature will rise. This does not mean the coolant is heating the ATF, it means the coolant is not able to remove as much heat from the ATF.
Always good to hear it "from the horses mouth", so-to-speak.
So many myths get dispelled in the real-world testing environment; the world of thermocouples and data recorders, working inside environmental chambers the size of a small home.
It separates the "Here's how I think it probably is" from "Here's how it IS"!
As always, thanks to Mark for sharing his life-long testing experience with us. He's a source I really trust for info in this area of expertise.
It appears that he yet needs a few to have his "full pull" of reps. Let's all send him some to fill it out for him, guys!
Well the whole 100 deg over out side temp I think is true, If it 95 out my trans get up to 195 and this is all pulling about 28000 GVW, now when I'm on some two lane roads I see temps around 200 to 210. I have a John wood's trans I don't run the bypass, I have tru cool cooler, mag-hytec trans pan and I run mobile one ATF. I don't pull over I just let the trans cool by not jumping all over the go peddle so much.
thanks Mark.
wow that '99 yr was a real fluke.wonder what they where thinking.you sure wouldn't want to try working the truck any while not going down the road,just as towing or heck even driving slow through traffic in summer heat,nor try plowing etc.etc.etc.good to see that changed that real quick.
going to have to agree,as iv read the rad's sections warms the temps in the past,im just not seeing it myself either.i'v decided to install my t-sat pre-rad to help get the temps up.
Originally Posted by Mark Kovalsky
170°F is ideal.
Also 170°F. Usually when towing heavy it will get hotter than that, but 170°F would be ideal.
Originally Posted by SpringerPop
We sure are fortunate to have Mark around here.
Pop
ideal;
1.
a conception of something in its perfection.
2.
a standard of perfection or excellence.
agreed,we sure are fortunate to have Mark around here.
your welcome Pop for me taking my time to show you how you can get closer to ideal trans temps in the winter.
I heard it works with the pressure of the cold oil opens it and hot thinner oil lets it close. When it was open the oil recycles and doesn't go through the coolers.
That can happen, but only well below 0°F. And we found that if the bypass opened from cold, thick ATF, it didn't close again until the ambient got quite a bit warmer. Once the cooler plugged from thick ATF it doesn't matter how hot the trans gets it won't force the cold oil out of the cooler.
