S. California Chapter Join Chapter, Leader:
October All Topic
Old Oct 6, 2011 | 10:11 PM
  #121
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Originally Posted by bpounds
Correct. Pumping the brakes resulted in most of the fluid discharge. I've studied that diagram after we did ours, and I don't think the way we did it gets fluid directly out of the steering head. It still gets changed, but it recirculates through the resevoir. All that means is you don't get as much of the old stuff out as you would like. Getting to the discharge from the steering head is difficult, while getting to the discharge from the brake booster is easy peasy.
Anything you recommend to get it all? Or should I just accept that it wont all come out?
Old Oct 6, 2011 | 10:21 PM
  #122
bpounds's Avatar
bpounds
In the diagram you will see that the PS and the PB are two separate fluid circuits. You would need to do the same procedure to the PS that is shown for the PB. But I think that is nearly impossible to do without a lot of disassembly. And I'm not sure you could still run the truck when you got down to it.
I think the written procedure is fine. I don't know how much fluid capacity is in the PS head and lines, but that amount of old fluid will be mixed with the new stuff.
I think if a guy wanted to get closer to a complete fluid change, the easiest way might be to do the procedure as written, then drive the truck for a week, and do it again the following weekend.
I'm satisfied with how we did it. But then, neither Steve nor I had a whining pump to begin with. So there it is, for what it's worth.
Editing to add: We used a turkey baster to suck as much of the fluid out of the resevoir as possible before we started the engine. So I think we were ahead of the game compared to that superdutypsd.com writeup. I definitely recommend that. We stuck a piece of tubing on the end of the baster to reach down in there.
Old Oct 6, 2011 | 10:29 PM
  #123
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Thanks Bill. I'll do it and get back to you guys with how it turned out. Appreciate the help.
Old Oct 6, 2011 | 10:31 PM
  #124
bpounds's Avatar
bpounds
Have fun. It is easy.
Here is that diagram:
Old Oct 6, 2011 | 10:37 PM
  #125
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I was unaware that we had a PS cooler until this very moment..
Old Oct 6, 2011 | 11:16 PM
  #126
SpringerPop's Avatar
SpringerPop
That fluid would get waaaaay too hot without any cooler.
Any continuously-operating hydraulic system has generated heat to dissipate somewhere.
The higher the pump's RPM, the more heat.
Pop
Old Oct 7, 2011 | 09:38 AM
  #127
bpounds's Avatar
bpounds
I'll bet you could cut that return hose where the fines filter is inserted, and get a good flush on the PS head. It has the potential to be a little messier, but could be done. Stick a bolt in the draw side of the return hose so it cannot suck air.
I wanted to add to the turkey baster idea above - make sure you replace the fluid you suck out with fresh fluid, BEFORE you start the engine. During the entire process you do not want the system to draw air.
Old Oct 7, 2011 | 02:27 PM
  #128
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
A $10 fuel cap and the '94 is emissions compliant for another 2 years
Old Oct 7, 2011 | 02:43 PM
  #129
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I didnt know you had a 94 F350.. Did you recently add it to your signature?
Old Oct 7, 2011 | 02:45 PM
  #130
SteveBricks
FTE Emeritus
No, it's been there for quite a while.
Old Oct 7, 2011 | 02:47 PM
  #131
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I must not be observant.
Old Oct 7, 2011 | 02:55 PM
  #132
67 Olfthfl's Avatar
67 Olfthfl
Good afternoon everyone.
Hope your having a fun Friday! (atleast after work anyway)
Old Oct 7, 2011 | 04:46 PM
  #133
bpounds's Avatar
bpounds
Just picked up my tux. Got the rehearsal dinner tonight. Tomorrow night my youngest will wed her beau. There is no peace around home today. Fortunately I'm leaving the whole bunch of them in a hotel tonight, so at least I can sleep later.
I'm worn out from watching all the running to and fro.
Old Oct 7, 2011 | 05:34 PM
  #134
SteveBricks
FTE Emeritus
Should be about check in time right now, shouldn't it?
Old Oct 7, 2011 | 06:46 PM
  #135
william_04_x's Avatar
william_04_x
Congrats Bill.
