Energy Suspension is what I think I ended up with.
The other styles bolt hole locations were too close to the original holes but not lined up. Didn't want to wallow/oval/elongate the mounting holes so I went with the center mount. You can see the original hole/s in the photos.
After climbing under my X to take measurements for before V & B-Mod Leaf swap, I couldn't help but notice my Bumps are shot. Any recommendations for replacements? Should I just go OEM or grab Energy Center bolt Bump-stops? Also, is there a center hole under the OEM if I buy a center bolt bump-stop?
Just for giggles guys, I have a 1/2" gap between front Bump-stop and upper front leaf bracket.... LOL I'd say my leafs are shot.
Just get whatever, they don/t do much anyway. I have a half inch too but it is fine, it only bottoms if I don't go slow for a big bump, not a problem.
