Body Mount Saga
Old Feb 17, 2012 | 09:58 AM
  #76
dangerous_sep's Avatar
dangerous_sep
Originally Posted by LivingLarge
The first 8 mounts from front to back are the same, I believe the ex has a total of 12 and sd's I believe have 10.
can anyone confirm this. if not i guess ill call energy and ask them for the specs on the 02 f250 poly mounts.
Old Feb 17, 2012 | 11:47 AM
  #77
LivingLarge's Avatar
LivingLarge
I'm actually at ford getting oil change... Had parts department print both for me...
Excursion has 6 locations total of 12 mounts.
The printout for the sd only shows 4 locations (that does not look right to me).
Total of 8 mounts.
Location of first 3 rows are the same part numbers. I can post the printout later tonight or in the morning.
Old Feb 17, 2012 | 12:48 PM
  #78
dangerous_sep
Total of 8 mounts.
thanks i just got off my lazy **** and used my resources seeing i own a damn shop n called my ford guy.
i can fax the print out to anyone if they need it its in pdf form, all of the bushings have been discontinued but he found like 20 sets for me in abeline. ill prob have them in monday latest tuesday.
a also called energy for the poly mounts and they dont make any as i and many others looked for in their catalogs, nor could he tell me if the 2wd f250 mounts would fit.
Old Feb 17, 2012 | 05:34 PM
  #79
scottf4444's Avatar
scottf4444
I too have been researching this with great frustration. I did not write this and have not tried it...I found this information on another site...but hopefully this can help us all out:
"Ive been a ford tech working in a dealership for ten years now and thought i might throw some knowledge out there on theese noises. Typically the pop under your feet during body flex was the cab mount bolt(under your feet) contacting the body on the nonthreaded portion of the bolt just under the washer. What we would do to fix is remove the bolt take it to a grinder and grind away on that nonthreaded portion of the bolt about till the washer ould come off. then with a die grinder and tapered stone bit hog the hole in the body out a bit sot there is now space between the bolt and the body. Then finally we put anti-sieze on the bolt nonthreaded portion just in case then slap it back in. I probably did this to atleast 200 pickups and excursions as it was a common problem on the first few years of these vehicles. As for a squeek noise the front leaf springs have plastic bushings on both ends between the leafs that wear out and then are very noisy on umps. Ford has a revised kit that replaced the existing bushings and adds a second thicker stacked bushing on top to extend the life of the bushings. Hope this helps someone!"
Old Feb 17, 2012 | 06:09 PM
  #80
Skip1970's Avatar
Skip1970
thanks allot maybe i will fix ours this summer.
Old Feb 17, 2012 | 08:46 PM
  #81
LivingLarge
Good info, sounds like this could work, I can see how the tapered stone bit can help this issue.
I just replaced mine last year and happy to report NO MORE noises.
Will send you reps when I get out of rep jail.
Old Feb 17, 2012 | 08:50 PM
  #82
LivingLarge
Since when have you become a wuss? It's above zero, get out there and getter done and report back! This could be the answer that will help a ton of fellow FTE brothers!
Old Feb 17, 2012 | 10:50 PM
  #83
Skip1970's Avatar
Skip1970
its not the weather, its that nasty road grime. man its gross, i hate to tap into anything in fear it will get in there once i break the seal! if i had a big dry fancy heated garage i still might not do it tell it had a day or 2 to thaw out.
the weather is really nice right now tho, bit of snow and 28 degrees. looks like it might be clear tomarrow. i got spring fever now, and really wanna start doing stuff.. probably a good thing too since i got more summer projects then i will be able to get to i bet.
Old Apr 18, 2013 | 03:10 PM
  #84
Bears-72's Avatar
Bears-72
The saga continues. After a year of silence from new body mounts, they have crapped out again. makes the truck sound like a piece of junk. I HATE IT!
Guess it's time to start the Jerry rigging.
Old Apr 18, 2013 | 11:09 PM
  #85
Skip1970's Avatar
Skip1970
Weld the. Body to the frame or get a louder radio
Old Apr 19, 2013 | 08:22 AM
  #86
Bears-72's Avatar
Bears-72
I'm thinking about shoving a Sleep Number bed under there.
XC6.0
Mar 9, 2016 05:33 PM
Watcher58
Sep 27, 2015 01:37 AM
RKCORPS25
Nov 15, 2013 07:24 PM
xman00
May 16, 2011 02:44 PM
TMyers269
Bronco II
Feb 27, 2005 09:51 PM
