Replacing Body Mounts?
Old Mar 7, 2016 | 11:31 PM
XC6.0's Avatar
XC6.0
Has anyone replaced all the body mounts on your X? Was it tricky? What does it entail? Do you have to disconnect things before you lift? Is it a DIY job? Or is it a nightmare? Can any give me detailed instructions? I know about the Dayco polyurethane mounts.
Old Mar 9, 2016 | 04:56 PM
XC6.0's Avatar
XC6.0
It's that bad? Or no one else has had a body mount go bad?
Old Mar 9, 2016 | 05:11 PM
LivingLarge's Avatar
LivingLarge
Here's a little reading for you...
https://www.ford-trucks.com/forums/1...dy-mounts.html
Old Mar 9, 2016 | 05:33 PM
XC6.0's Avatar
XC6.0
Thanks, I read most of it which is about whether its your body mount, etc. I know its a body mount, the one under the passengers feet and the ones in the front are cracked. I am looking for replacement details from someone who has done it. In order to replace one, you have to remove all 12 bolts which is most of the work, so you might as well replace all of them. An entire kit of poly mounts from Daystar is only about $160.
Watcher58
Sep 27, 2015 01:37 AM
TMyers269
Bronco II
Feb 27, 2005 09:51 PM
rhider
1978 - 1996 Big Bronco
Aug 16, 2003 10:17 AM
Riso79
Dec 21, 2001 01:55 AM
