Body Mount Saga
Old Jul 27, 2011 | 08:40 AM
Bears-72's Avatar
Bears-72
Body Mount Saga
The garage I give all my money to tells me that the body mounts are becoming obsolete and they'd have to get them from Texas. There'd be extra freight charges which would bring the cost for just the front 2 mounts installed to $715. I thought these kits were $90/kit?
He said there are actually 6 down each side. (I thought there were only 3.)
He also said the back body mounts are really hard to get and will be more expensive.
This creaking is driving me nuts. I've got to get it taken care of.
Old Jul 27, 2011 | 09:43 AM
Joe28443's Avatar
Joe28443
Joe28443
Man mine is too, I'm borderline wanting to sell it because of it
Old Jul 27, 2011 | 10:10 AM
labman1014's Avatar
labman1014
Where r u? I'll do them for parts and labor for half that!!!
Old Jul 27, 2011 | 11:39 AM
cbradford's Avatar
cbradford
Sounds like your getting taken!!!!
I would check around.
Old Jul 27, 2011 | 12:21 PM
labman1014's Avatar
labman1014
My dealer doesn't charge for shipping on parts.
Old Jul 27, 2011 | 01:27 PM
LivingLarge's Avatar
LivingLarge
It does not come in kit form, Upper mount/Lower mount, bolt/shim (4 Parts). they are about $90. for each setup. Ford has plenty in stock. Hope this helps i went through this for months. Its like driving a $400. truck.
Old Jul 27, 2011 | 01:29 PM
LivingLarge
I would start with the 2 Under your feet both drivers and passenger side, that might do it for you.
Old Jul 27, 2011 | 03:01 PM
Joe28443's Avatar
Joe28443
Joe28443
I thinks thats where my problem sounds like its coming from under my feet.
Old Jul 27, 2011 | 03:31 PM
LivingLarge
When done you will think your driving a new EX.
Old Jul 27, 2011 | 03:54 PM
Joe28443's Avatar
Joe28443
Joe28443
Good because now i feel like I am driving a 70 model. How long did it take you and did you just do one on each side under your feet
Old Jul 27, 2011 | 04:06 PM
LivingLarge
Joe, i had my local Ford Dealer do the Job. I had posted this a while back, keep in mind the Ford manual states you must loosen all the mounts before replacing one. I talked the tech into just lifting the cab a little were the specific mount was to be changed. (This took him 30 minutes per side).
Very straight forward job. Also, this was not my first time, make sure the parts department finds you the SHIM. The Shim was introduced years later, people claim that this was Ford's fix to a very common problem with our trucks. Without it i only got a couple of quiet months.
Yes, only did position 2... this is the first to fail due to its the position with the most amount of flex.
Hope this helps,
Old Jul 27, 2011 | 07:50 PM
Bears-72's Avatar
Bears-72
I was planning on doing just the first 2 sets under my feet first, but I thought it'd be around $400.
Who's the Ford parts 'guy' here? Does he have these parts?
Old Jul 27, 2011 | 07:52 PM
Bears-72's Avatar
Bears-72
...and I only need to replace 3 down each side, right? (Most of the creaking is under my feet, but I do hear it all over)
Old Jul 27, 2011 | 07:57 PM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
INS ASY-BDY BLT UPR YC3Z1000154AA upper x2
INS-ASY-BDY BLT LWR YC3Z1000155AA lower x2
www.partsguyed.com
Old Jul 27, 2011 | 08:11 PM
quietman's Avatar
quietman
It sounds like you took your rig to Chris at Capistrano Ford...
