S. California Chapter Join Chapter, Leader:
July All Topic
Old Jul 5, 2011 | 07:24 AM
  #151
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
1) Indicated Horsepower is the amount of HP delivered to the top of the piston during combustion and is mathematically calculated. What is Brake Horsepower.
3) A 4-stroke motor operating at a constant 2100 RPM will complete a single stroke every ____ seconds. (A calculator is permitted)
4) When a piston reaches its highest point in the cylinder, this is called what? Conversely, what is the lowest point in a piston's travel called?
1) Brake horsepower is measured at the crankshaft
3) 2100/60 = 35
4) TDC/BDC
Old Jul 5, 2011 | 08:07 AM
  #152
IB Tim's Avatar
IB Tim
Morning all...back to work
Old Jul 5, 2011 | 08:48 AM
  #153
davewave649's Avatar
davewave649
Originally Posted by TreySpooner65
Trivia Time:
5) Ambient air contains approx. __ % Oxygen. An exhaled breath contains __ % Oxygen.
10) What is the smallest country?
Vatican City is excluded for this question.
This is borederline on a trick question, as the country is not recognized by all sovereign nations, while others have recognized it. There is a fun story behind it for anyone who knows it.
Ambient is around 20% if i remember right and not sure bout the other one
Smallest country is SeaLand, a little island off of Great Britain
Old Jul 5, 2011 | 10:24 AM
  #154
bigrigfixer's Avatar
bigrigfixer
The Pacifier
Trivia Time:
2) What is the difference between Indicated Horsepower and Brake Horsepower called?
1) Brake hp, measured at the flywheel.
2) The difference is theoretic vs actual. Or maybe parasitic loss.
3) 70 strokes per second
4) top dead center, bottom dead center.
Old Jul 5, 2011 | 10:27 AM
  #155
SpringerPop's Avatar
SpringerPop
FlashMob on Ol' Cape Cod
This happened last Friday on Cape Cod.
Really cool, and just in time for this last weekend!
YouTube - ‪Flash Mob at Cape Cod Stop and Shop‬‏
Pop
Old Jul 5, 2011 | 10:54 AM
  #156
SteveBricks
FTE Emeritus
Originally Posted by bigrigfixer
1)
I was going to ask you what I was missing here, but after thinking about it I realize that my 35 figure is cycles per second (i.e. up/down being a single cycle.).
I think
Old Jul 5, 2011 | 11:21 AM
  #157
jake08's Avatar
jake08
Pop
Great, these are the grass roots folks who make our country what it is.
Old Jul 5, 2011 | 11:56 AM
  #158
DieselHardware's Avatar
DieselHardware
I've always wanted to do one of those.
Old Jul 5, 2011 | 12:20 PM
  #159
Jetcopterpilot's Avatar
Jetcopterpilot
I think
on a 4 stroke up and down twice is a single cycle!
Old Jul 5, 2011 | 12:32 PM
  #160
SteveBricks
FTE Emeritus
That's true...and that constitutes 2 revolutions.
The question is kind of confusing ...and I believe intentionally misleading(to me, anyway)
I don't really see the relevance of it being a 4 stroke motor, since the question asks about a single stroke. A single revolution of the crank is still a single revolution of the crank, and a piston goes up once and down once during each revolution whether it's a 2 stroke or 4 stroke, and a single stroke is one half of a revolution.
Old Jul 5, 2011 | 12:45 PM
  #161
Jetcopterpilot
I don't really see the relevance of it being a 4 stroke motor, since the question asks about a single stroke. A single revolution of the crank is still a single revolution of the crank, and a piston goes up once and down once during each revolution...be it 2 stroke or 4 stroke, so a single stroke is one half of a revolution.
The 4 stroke only fires the piston every other revolution, of the crank so if it is running at 2100 it is firing each piston 1050 times per minute, which would be 17.5 times per second... yes the question is very misleading!
Old Jul 5, 2011 | 01:33 PM
  #162
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Trivia Time:
Brake horsepower refers to the amount of usable power delivered by the engine to the
crankshaft.
Indicated horsepower can be as much as 15% higher than brake horsepower.
The difference is due to internal engine friction, combustion inefficiencies, and parasitic
losses. The ratio of an engine's brake horsepower and its indicated horsepower is called the
mechanical efficiency of the engine. The mechanical efficiency of a four-cycle diesel is
about 82 to 90 percent.
If a four-stroke engine running at a constant 2100
revolutions per minute (rpm), the crankshaft would be rotating at 35 revolutions, or
12,600 degrees, per second. One stroke is completed in about 0.01429 seconds.
The highest point of travel by the
piston is called top dead center (TDC), and the lowest point of travel is called bottom
dead center (BDC). There are 180* of travel between TDC and BDC, or one stroke.
Change of topic so no one person can dominate the trivia game!
21%, 16%
6) What is considered "normal" blood pressure levels for an adult?
120/80 mmHg
7) During CPR of a person with no pulse present, the rescuer will compress the chest creating a pulse, and there for a blood pressure. If that blood pressure were measured, what would the blood pressure be?
15/0 mmHg
8) Statistically, what day of the week are you most likely to be struck by lightning?
Sunday
BONUS QUESTIONS!
9) What magazine did Huge Hefner work for as circulation manager, while raising funds to start Playboy?
Children' Activities magazine
Sealand (someone got this right!!)
I had to stop the agony of you guys trying to figure out the answers!
Source:
1-4: Department of Energy Fundamentals Handbook, Mechanical Science Vol. 1
5-8: EMT Class
9: Dunno. Just knew it.
10: HowStuffWorks.com Podcast
Old Jul 5, 2011 | 02:18 PM
  #163
Bear13861's Avatar
Bear13861
Source:
5-8: EMT Class
I was enjoying the atempts, not much agony... But some funny and interesting responses.
Mark.
Old Jul 5, 2011 | 02:40 PM
  #164
bpounds's Avatar
bpounds
Open to interpretation. Stroke versus revolution.
At 2,100 revolutions per minute (RPM) the engine would be rotation 35 times per second. But is a revolution a stroke? We refer to compression stroke, exhaust stroke, intake stroke, power stroke, etc. Implying that a stroke is different than a revolution. To be correct, one could say that there are 17.5 compression strokes per second.
And in evidence of their ambiguity, I submit the very next question. Here they differentiate between a stroke and a revolution. They screwed up their own premise.
Old Jul 5, 2011 | 04:42 PM
  #165
67 Olfthfl's Avatar
67 Olfthfl
Hi all!
Hope everyone had a fun & safe 4th!
I had a rough night lastnight. Disrespectful preteen pretty much ruined the day. My 12y/o son stayed the night at a friends & stayed up all night watching TV, only to come home & expect to go to sleep - NOT! He did it to himself & we had things to do, so he had to stay awake & deal with it. (all the while complaining & making our lives hell cause we wouldn't let him sleep until about 1pm)We went to a BBQ at our neighbors around 4:30 & I left hubby & the kids there & walked home (2 blocks) at 8 & went to bed around 9pm. They came home shortly after 9. We didn't even watch the fireworks!
