Missouri Chapter Join Chapter , Leader:77&79F250
Ches's Bronco build!
Old Nov 11, 2011 | 06:33 AM
  #121
77&79F250's Avatar
77&79F250
Moderator & parts slinger
There is a "DuPont" ??? carpet dye I think that someone used on here with good results. Maybe the new search function will work better ??
Old Nov 11, 2011 | 08:35 AM
  #122
earthquake68's Avatar
earthquake68
I used to do this all the time. Any carpet dye will work. Just understand especially in the foot rest area, it's temporary at best. About once a year you'll have to re-shoot it. Other that that, nobody will be able to tell if you do a nice job.
Old Nov 11, 2011 | 09:30 AM
  #123
cyclopsblown34's Avatar
cyclopsblown34
Ches, if you're still at Slo Reilly, Dupont Vinyl Dye works great and hopefully you can get it cheaper than I do, I pay about 45.00 for a pint I think. Like Alan said, in the foot/heavy wear areas, you will need to reapply it occasionally.
Old Nov 11, 2011 | 10:15 AM
  #124
pintoches's Avatar
pintoches
I might just pull the carpet to, die it black!
Old Nov 11, 2011 | 10:25 AM
  #125
tcbofade's Avatar
tcbofade
It will be a bit of a project, but if you can remove the carpet from the rig and dye it outside, let it dry, then reinstall, I'll bet you a nickel you'll be glad that you did. Should come out good.
Good luck, Ches.
Old Nov 11, 2011 | 10:38 AM
  #126
77&79F250's Avatar
77&79F250
Between the glue and the door track plate screws, floor pan seat belt bolts (large star head PITA), I would leave it in. If you pull it it seems to never go back in right.
Pull it and do a "Herculiner" bed liner kit in it and be done. If it's blue now changing to black should go easy enough?
Old Nov 11, 2011 | 11:04 AM
  #127
pintoches's Avatar
pintoches
The blue carpet in my bronco sucks, the gold carpet in the parts bronco looks brand new! going to have the seats out anyway?
Old Nov 11, 2011 | 11:40 AM
  #128
77&79F250's Avatar
77&79F250
Go for it, and post up some pics!
Old Nov 13, 2011 | 12:42 PM
  #129
zstangkrewson's Avatar
zstangkrewson
your carpet issue.... jcwhitney has awesome prices on carpets... if yo ureally dont feel like re-inking the carpet every year, you could put out for new carpet, just a thought, the roll on stuff would be a huge improvement over teh bare metal, not only would it make it a litle quieter while driving, but you would benefit from rust prevention and the heat wouldnt be as bad on warm days. i would definately roll on the whole inside floor for those reasons alone! when will you get some more pics up?
Old Nov 13, 2011 | 12:43 PM
  #130
zstangkrewson
btw, anyone looking for a nice high-boy??? 1977 FORD HI-BOY 4X4
Old Nov 13, 2011 | 04:21 PM
  #131
earthquake68
You suck! I wasn't looking for a hi boy until I saw the ad. That's a nice truck.
Old Nov 13, 2011 | 04:42 PM
  #132
77&79F250's Avatar
77&79F250
Its been off and on CL for a while now, I have been eye balling it to. So sell the Nova and go shopping
Don't you hate a guy that supports you buying another truck, lol.
Old Nov 14, 2011 | 10:24 AM
  #133
pintoches's Avatar
pintoches
Got the trim off the Bronco one step closer to paint!
Old Nov 17, 2011 | 09:33 PM
  #134
pintoches's Avatar
pintoches
found some mixed paint I can buy cheep today,hopefully I say it right, ready to spray single stage acrylic enamel
I was kinda hopping for a brighter green?
Old Nov 18, 2011 | 08:08 AM
  #135
cyclopsblown34
Add a little fine aluminium toner to it and maybe a little yellow and white toner. That is if your store mangler will let you at the mixing station.
I just thunked about it, if this is a single stage enamel, you might want to avoid any metallic. You can't sand and polish metallic single stage and get a nice finish.
