Missouri Chapter Join Chapter , Leader:77&79F250
Ches's Bronco build!
Old Nov 18, 2011 | 08:19 AM
  #136
pintoches's Avatar
pintoches
Originally Posted by cyclopsblown34
Add a little fine aluminium toner to it and maybe a little yellow and white toner. That is if your store mangler will let you at the mixing station.
I just thunked about it, if this is a single stage enamel, you might want to avoid any metallic. You can't sand and polish metallic single stage and get a nice finish.
I too was thinking about trying to add some yellow and white! I have been learning to mix for a while, but its all done buy weights, Don't know how much to ad to change the color,
Also this is ready to spray so no reducing, Will the gal be enough to paint the bronco?
Old Nov 18, 2011 | 08:44 AM
  #137
cyclopsblown34's Avatar
cyclopsblown34
Which paint is it? It should be enough to cover the outside of the Bronco if you spray with an HVLP gun over primer/sealer tinted with a little bit of the paint.
Old Nov 21, 2011 | 10:46 AM
  #138
pintoches's Avatar
pintoches
Gm 14bolt with 4.10 gears!
Old Nov 21, 2011 | 01:20 PM
  #139
j20owner's Avatar
j20owner
I've got one of those laying around. Hopefully one day it'll find it's way under the rear of my Jeep.
Old Dec 19, 2011 | 03:43 PM
  #140
pintoches's Avatar
pintoches
Got some stuff done on the Bronco passenger side hub, washer fluid tank, ashtray And seats!
before
New seats
Old Dec 19, 2011 | 04:12 PM
  #141
earthquake68's Avatar
earthquake68
Fancy! .
Old Dec 19, 2011 | 04:17 PM
  #142
cyclopsblown34
That things gonna be too nice to take to SMORR.
Old Dec 19, 2011 | 05:24 PM
  #143
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Oh lookie lookie shiny new stuff.....looks good Ches.
Old Dec 19, 2011 | 05:30 PM
  #144
pintoches's Avatar
pintoches
Thanks guys!
The passenger side 1/4 turn locking hub kept locking on its own? Changed it out with a full turn hub so will see what happens?
Old Dec 19, 2011 | 08:00 PM
  #145
earthquake68
I had that happen on my black Chevy. There's a little plastic "bump" on the **** that locks it in place. Over time it gets worn away and doesn't stay locked. It should be fine with a new hub.
Old Dec 22, 2011 | 08:48 PM
  #146
pintoches's Avatar
pintoches
The Bronco is getting a new 4bbl Intake for Christmas Thank you grandma!
should I use the Felpro Vally pan or get edebrock gaskets?
Alan do you have time to help with the carb I need to get the holly 600 rebuild (or finished rebuild)
Old Dec 23, 2011 | 09:08 AM
  #147
tcbofade's Avatar
tcbofade
Yay u!
Old Dec 23, 2011 | 09:17 AM
  #148
earthquake68
Sure Ches, just bring what you have and the kit and we'll get it going again. Consider it a Christmas present.
Old Jan 10, 2012 | 09:49 PM
  #149
pintoches's Avatar
pintoches
Ok so I now have a 14 bolt with 4.10s that matches my dana 44, and a set of Dana 44 Chevy outers! Going to use 78 Chevy front calipers and rotors all around my Bronco!
Next I need 4 Chevy calipers to use as cores!
Old Jan 10, 2012 | 10:13 PM
  #150
earthquake68
Uuuuuh, ...I don't know, Ches. There's a LOT of Chevy parts going on that Bronco.
..............lol, J/K!
