Missouri Chapter Join Chapter , Leader:77&79F250
Ches's Bronco build!
Old Oct 5, 2012 | 07:21 PM
  #241
earthquake68's Avatar
earthquake68
Did you use gasket sealer around the intake ports? A crush metal gasket isn't usually enough to seal. Especially if the manifold is aluminum.
Old Oct 5, 2012 | 07:26 PM
  #242
j20owner's Avatar
j20owner
If you're not going to be using that holley, I'd like to have it back.
Old Oct 5, 2012 | 07:35 PM
  #243
pintoches's Avatar
pintoches
No just the metal felpro gasket, Did not know to use the sealer.
Old Oct 5, 2012 | 08:29 PM
  #244
earthquake68
Take some starting fluid and spray the intake gaskets with it running. If the idle changes, you have a leak. I'd still pull the valve covers to be thorough.
Old Oct 6, 2012 | 01:41 AM
  #245
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yea also do not use those dang rubber s shaped intake gaskets on the front and back of the manifold thay always slip out. Use a healthy amount of the copper-tex high temp stuff.
That was my problem with ol red at first, then I got a stuck valve and bent a few pushrods. Easy fix, I swapped the moter outa the rearended bronco with 90,000 on it.
Old Oct 6, 2012 | 07:52 AM
  #246
whiskey runner's Avatar
whiskey runner
it is always good to have plenty of spare parts huh rich..
Old Nov 2, 2012 | 01:14 PM
  #247
pintoches's Avatar
pintoches
Pulled the distributor, and dropped the oil pump shaft in the pan, Is there any thing wrong with leaving it in the pan and using a spare?
Old Nov 2, 2012 | 06:54 PM
  #248
77&79F250's Avatar
77&79F250
Woops....I would guess it would be ok till it gets bounced or thrown/sloshed up into the lower internals?? You are off roading it some day, right?
Or maybe it will be ok?? it might be heavy enough to stay put in the bottom of the pan. I am sure you will get more input here shortly, sorry for your back luck.
All else fails drop it and tilt it enough to get a magnet and go fishin.
Old Nov 2, 2012 | 07:10 PM
  #249
pintoches's Avatar
pintoches
Got my drive shaft tonight!
Old Nov 2, 2012 | 07:21 PM
  #250
77&79F250's Avatar
77&79F250
Are you good with its condition? Should be a bolt and go......Thanks Unk Bob for the parts drop off. I figured he dropped it off since he went to Branson today?
Old Nov 2, 2012 | 08:22 PM
  #251
pintoches's Avatar
pintoches
My buddy Richy Stopped at Alan's on his way home from from Work today.
Dropped off Some wheels for one of Alan's cars, Wheels to be sandblasted, vinyl for earthquake, And picked up my drive shaft!
Old Nov 3, 2012 | 12:10 AM
  #252
77&79F250's Avatar
77&79F250
At least you got it, hope it works for you, I am sure it will.
Old Jun 2, 2013 | 08:00 PM
  #253
pintoches's Avatar
pintoches
Wow has it really been 7 months since I posted an update on the bronco?
Turns out the miss was a bad coil wire. The coil was going bad and leaked oil in the end of the wire. I changed the coil but never thought of the wire.
Have not done any thing cool to the bronco in a long time. guess I got caught up with the new family. Wife is 29 weeks now. Adelyn Grace Lathim should be here before to longer! Getting me a daddy's girl.
Loving the new job, turning wrenches full time is a blast, learning so much! My boss/owner is real cool and laid back.
About to get my wife a Ford! 06 Expedition EB, 4x4, 3rd row, sunroof, rear air, DVD the works!
Sure miss being on line with you guys, butt what I got now is a lot better!
Old Jun 3, 2013 | 09:05 AM
  #254
earthquake68
It only takes a second to drop a line or two. Keep in touch and congrats again on the new addition. ......by the way, we still like pictures.
Old Jun 3, 2013 | 12:06 PM
  #255
77&79F250's Avatar
77&79F250
Welcome back around and congrats on the new additions, so no more O'reilly's huh?
Stop by when you can and remember the Off Road Jamboree/ FTE G2G is the 22/23rd June.
