The camper thread! Pulling, using, equipment, maintenance!
Old Aug 17, 2014 | 11:48 PM
  #706
Bently_Coop's Avatar
Bently_Coop
Stewart- Just found a link that may help shed light.
Battery School | Batteriesnorthwest.com | Advantages and Disadvantages of using two 12 volt batteries connected in parallel or two 6 volt batteries connected in series.
Old Aug 18, 2014 | 12:00 AM
  #707
ExxWhy's Avatar
ExxWhy
The GC batts have taller and thicker plates, and as a true deep cycle battery are designed to be run down lower than a starting type battery. Even what is advertised as a deep cycle/starting battery is something of a compromise. It only matters if you plan to camp off the grid a lot. A lot of good info at this link. The 12volt Side of Life (Part 1)
We spent 7 days without being plugged in when we were in Yellowstone a couple years ago, and that included some furnace time each night (kept it 58 or so inside) and water pump enough for showers for 3 every other day. We're pretty conservative with the lights when needed. YMMV on that, all depends on how much stuff one wants to run.
Old Aug 18, 2014 | 06:29 PM
  #708
Snowseeker's Avatar
Snowseeker
Just pulled and got done unpacking some stuff and cleaning the X out from the trip.
The rig is starting to look comical I think.
Clear water lake.
And one of these guys watching me.
Old Aug 18, 2014 | 09:18 PM
  #709
ExxWhy's Avatar
ExxWhy
Quite the flotilla! Good stuff!
Old Aug 18, 2014 | 10:16 PM
  #710
william_04_x's Avatar
william_04_x
Comical? No way! That rig is definitely ready for an excursion. Looks like fun to me.
Old Aug 18, 2014 | 10:23 PM
  #711
Restlesswildman's Avatar
Restlesswildman
Originally Posted by Stewart_H
I probably should have asked what controller you have first. Delay??
Stewart
I have a hopkins agility. Hopkins Towing Solutions Agility? Brake Control - Tractor Supply Co.
The delay I was talking about turned out to be the sensitivity setting. IT is possible I set it at 5 which is the highest sensitivity. I doubt I would have done that, but who knows after the kast month.
Old Aug 18, 2014 | 10:26 PM
  #712
Restlesswildman
You could put all them there kayaks on either the EX or the trailer and have a new float for going down the river.
Old Aug 18, 2014 | 10:28 PM
  #713
william_04_x
You'll get your confidence back, Wild man. It's just a matter of getting it all tuned in.
Old Aug 23, 2014 | 09:39 PM
  #714
2006lariat's Avatar
2006lariat
So I put all led lights in my camper interior....... they suck? They are 6000lumen, and not very bright compared to the regular bulbs. So now the question, should I get higher lumen bulbs, or do led's just not spread like incandescent bulbs?
Old Aug 24, 2014 | 12:55 AM
  #715
hav24wheel's Avatar
hav24wheel
All depends on the LED
My camper has all LEDs in it and they are BRIGHT. Idk what they are though. They came in it from the factory. They are little strips in the lights.
Old Aug 24, 2014 | 04:26 AM
  #716
2006lariat's Avatar
2006lariat
My camper had 921 style bulbs everywhere, and they are bright. Problem was the kids left the bathroom light on, and it got so hot it melted the fixture. So I searched 921 style led, and found these. For $11, I couldn't go wrong (& I don't think I did) and is they didn't work, well I'm not out a lot.
I looked at, like, a "paddle" led for it to. They style may work better as all the light would be shining down.
The current ones have 5 LEDs, 4 around, 1 at the end, so maybe I will try the paddle style.
Edit: 6000 is not the lumen rating apparently. I have no idea what the lumen is. I also have no idea what the 6000k stands for either.
forgive my ignorance.
Old Aug 24, 2014 | 06:35 AM
  #717
WE3ZS's Avatar
WE3ZS
Adam, the 6000k is the color temperature, lower numbers are more yellow and the higher number work towards a blueish color, 5000 to 6000 should be a bright white if I recall correctly. The "paddle" style LED units should work much better in the standard camper type light fixture as all of the LEDs will be firing outwards through the lens cover, the type you have don't do well without a chrome or polished reflector behind the bulb to throw the light output, the white plastic of the camper fixture isn't a good match for your style bulbs.
Old Aug 24, 2014 | 06:39 AM
  #718
2006lariat's Avatar
2006lariat
My light fixtures have chrome "backers". But I think you are right. The 5 led bulbs don't utilize the area the same as the incandescent.
like I said I'm only out a couple bucks, and am learning about LEDs.
Oh, they are kinda bluish.
Old Aug 24, 2014 | 09:47 AM
  #719
hav24wheel's Avatar
hav24wheel
Here's how mine are.
Old Aug 24, 2014 | 12:48 PM
  #720
pkthomas's Avatar
pkthomas
Does anyone use a front receiver to park their camper? If so do you go over the weights for it? They all seem to max out at 500/5000lbs. Can you go over those for just maneuvering around right spots?
