The camper thread! Pulling, using, equipment, maintenance!
So.... My front window stone guard was cracked and the aluminum frame broken from a previous hurricane. Not reparable in my mind, and haven't used it in years... but decided to fix it. So to make a long story short... the cheapest I could find was a used one in GA for $500. Even went to a marine shop to make one and a a plastic fabricator near me... all MORE expensive. The price made my redneck-ness kick in. The OEM rock guard/window cover measured 65 x 24 and its 3" thick ... so I went out and bought one of those 5' outdoor, UV stable, plastic top banquet tables for $79. it measures 60 x 24 by 2 3/4''. Removed the metal legs/frame from the the table top. Transferred the old hinge from my OEM cover, bought 2 gas shocks $17, and spring locking pins $6. Final touches not finished, but 100% fit. I may paint the logo back on... krylon plastic paint works .
I've been using an RV broom and dust pan, a small handheld vacuum and then mop with a Swiffer disposable.
I'm thinking of getting a small Dyson V7.
Any of those options will pull 10K. The trick is where you'll be pulling, for how long, and how much you want in the way of performance. Tom will tell you (and rightly so) that the V10 will perform flawlessly with proper gearing for the weight and tire size. So, will need a bit more info. Short answer is: any will do. Long answer is: depends on a whole lot of stuff.
What part of the country are you pulling in? Mountains? Flat? mix? Western or eastern? There are some good hills in the east, but out west is a bit different with the added issue of altitude.
Expected tire size?
Those two answers will open up a whole host of better information to your question.
Expected tire size?
I apologize for the lack of detail in my original question. I live in Colorado (which is where I will be doing nearly all of my camping) so mountain hills are a reality of life for me - oh and altitude. We're typically within a 2 hour drive to our camp site so we really don't plan on pulling over a super long haul.
As for tire size, not exactly sure here, but I really can't imagine I'd be running anything larger than a 33, but more likely something closer to a 285 under a 2-4" lift.
My goal is to have the most reliable and capable setup possible so I don't have to worry about pushing the capabilities of the rig with the camper behind me. Hope that helps and thanks again for everyone's thoughts and experience here - I am very grateful!
I can't speak from personal experience with the V10, but from what I've read, Tom ( @WE3ZS ) would probably recommend a gear change with the V10 even at 33" tall tires. I can say that at 10K, the 6.0 in the stock configuration will work fine, but you'll have to manage it well. You can wake them up quite a bit with tuning, but then you're running into some of the weaknesses that the 6.0 is notorious for. As an example, in a stock configuration 6.0 (EGR delete only), I had trouble running the AC in the summer pulling my camper and loaded down with family and dogs. Probably around 8K all in on the camper but I never weighed it. Generally, the ECT and EOT would rise to the point that I didn't like it to be (over 220) and the fan would be screaming. I never had the typical 6.0 issues, but I obviously didn't push it too hard either. A head wind made towing almost unbearable on flat ground (which you'll probably experience). I guess what I'm getting at is that the 6.0 wasn't great in a stock configuration as far I'm concerned. It had good get up and go, and it would pull all day as long as I kept track of everything and managed the process of towing. That's one of the reasons I went to the Cummins, but that's another story.
For the reliability aspect, in a stock configuration, it's 6 in one and half dozen in another on the 7.3 and V10 as long as what you buy is well maintained and hasn't been abused. The 6.0 can be reliable, but it's a bit more work on your part for maintenance, aftermarket parts, and some engine work. If you want plug and play, I'd focus on a really well maintained rust free V10 and get the gears changed or hunt for a set of axles with 4:30's or taller.
MB is so much more relaxed in the winter, not crowded, but stuff is still open. The campground is also fairly quiet, more adults and they do have programs for campers to stay for 1 month at a reduced cost.
After that we drove to a every trip favorite stop, Lees Farmers market Lee's Farmers Market | Myrtle Beach in Murrells Inlet for their corned beef sandwich. Highly recommended!
Needed diesel, stopped at a Murphy station, 2.08 a gallon, all of the other stations around were 2.39 and up. Back at the camper, getting dark and starting to rain. We leave tomorrow. All and all a good 1st of the year trip.
For a 2007 Nash, very little rust, and still solid floor. no signs of water leakage.
Question... what do y'all have on the bottom of your trailers? anything other then coroplast?
