S. California Chapter Join Chapter, Leader:
March All Topic
Old Mar 19, 2011 | 12:05 PM
  #196
bpounds's Avatar
bpounds
Originally Posted by SteveBricks
Mine is definitely due, and since it's a two man operation that sounds like a great idea. We can do yours first
Can't swing it today. How about tomorrow if the weather holds?
Not today. I'm going to have to shop for the fluid, and I will pick up some tubing from work next week. I was thinking of Friday.
I would still like to suck as much old oil out of the res as possible instead of running it all through the pump. Do you have one of those sucker pumps?
Old Mar 19, 2011 | 12:20 PM
  #197
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Friday works for me.
I've got a vacuum pump. Got a turkey baster too. I'll bring them both.
Old Mar 19, 2011 | 12:22 PM
  #198
bpounds's Avatar
bpounds
Good. I think it will be worth pulling out what we can. Then you are not mixing hardly any of the new fluid with the old.
What fluid are you thinking?
Old Mar 19, 2011 | 12:35 PM
  #199
SteveBricks
FTE Emeritus
I don't know. I'd always figured to use Mobil 1...had no idea it's no longer available until today when I read it here.
There's always the Motorcraft stuff...might get a decent price @ Sunrise/w the SoCaps discount. Synthetic would be nice, like you said...maybe Royal Purple?
Royal Purple Transmission Fluid
Old Mar 19, 2011 | 12:41 PM
  #200
bpounds's Avatar
bpounds
Sometime this afternoon I will browse Pep Boys and then Walmart if necessary. RP would be good if they have it, and I think the Boys do carry it. I don't think it would be worth driving to Fontana for any discount. I heard they pulled Valvoline synthetic too, which is another I would have used.
Old Mar 19, 2011 | 12:47 PM
  #201
SteveBricks
FTE Emeritus
There's a Napa on Slauson and an Auto Zone on Carmenita that supposedly carry the stuff:
NAPA / Genuine Parts Company
11720 East Slauson Avenue
Santa Fe Springs, CA 90670
(562) 945-1246
AutoZone
10126 CARMENITA
SANTA FE SPRINGS, CA 90605
562-946-7709
Old Mar 19, 2011 | 12:54 PM
  #202
SpringerPop's Avatar
SpringerPop
If you consider how often you will likely change it, synthetic might just be over-kill (though I've NEVER heard of that being a bad thing!).
I changed mine with Mobil 1, but that was before the ban. I also have a spin-on filter on this system,
http://springerpop.net/F350/hydraulic_filter.html
so it's conceivable that mine will go for a hundred thousand or so before the next addressing. I know this might be pushing even synthetic, but forgetting about these things is the reason I have all those filters.
Any specific reason for going syn? Consider adding a Magnefine?
www [dot] superdutypsd [dot] com/magnefine_power_steering.php
Pop
Old Mar 19, 2011 | 01:00 PM
  #203
bpounds's Avatar
bpounds
Just hoping it will last longer, I guess. Mine looks pretty dark. If the dealer did what they said they did, which is a big IF, there is only 45k on this fluid. I think it looks worse than it should for so few miles. Maybe the extra heat stabilization would be worth the money for synthetic.
I'm not all that hot on a filter. I know many here love the idea. Eh, not a big deal to me. Certainly cheap enough.
Old Mar 19, 2011 | 01:12 PM
  #204
SpringerPop
There DOES seem to be less oxidation to synthetic at elevated temperatures.
Pop
Old Mar 19, 2011 | 01:19 PM
  #205
bpounds's Avatar
bpounds
Yes, and I can guess that the system gets pretty hot when off-roading, backing trailers, etc. Lots of heat, little air flow. I believe the fluids lose their anti-foaming additives primarily due to heat over time. When it starts foaming, you gots problems.
Old Mar 19, 2011 | 01:24 PM
  #206
SpringerPop
Most of the heat in the entire system is generated by the nature of the pumping system. Positive displacement pump, and anything not used is "bypassed", so there is energy being pumped into the oil even if there is no usage.
The heat buildup is more related to engine RPM than anything else.
And yes, air flow over the cooler is the most important part of cooling.
Pop
Old Mar 19, 2011 | 03:08 PM
  #207
bpounds's Avatar
bpounds
Found Mobil 1 ATF at Autozone in Whittier. Was very surprised. Pep Boys didn't have anything synthetic.
The date codes on these bottles are 01/13/11. Not sure what to make of that.
They had six. I bought 5. Would have bought enough for you, Steve, if they had had all 8. I guess it is out there if you drive around long enough.
Old Mar 19, 2011 | 04:13 PM
  #208
Bdox's Avatar
Bdox
Old Mar 19, 2011 | 06:09 PM
  #209
SpringerPop
Bill,
I just did a search of the Mobil website for "Mobil 1 Synthetic ATF California"
Got four hits, but none had anything that resembled:
"Mobil 1 Synthetic ATF has not been recalled. It is, however, temporarily
unavailable for sale in the state of California. We can assure you that
there are no performance or safety concerns with Mobil 1 Synthetic ATF.
ExxonMobil stands behind this product. Thank you for your interest and
loyalty."
which it previously had.
Maybe they're good-to-go again.
Let's hope...
Pop
Old Mar 20, 2011 | 03:46 AM
  #210
T8R's Avatar
T8R
My Mightyvac kit came with a few different bottle caps and adapters designed to auto-fill a reservoir for jobs like this. (Already have the Motorcraft ATF sitting in the garage to do this job - it's part of what i've been putting off.) Wondering if using the Mighty bottle caps will make the job manageable for one person to do.
If it works out - you guys are welcome to borrow it. (Has all the adapters to connect the clear line too, even if it's not exactly the right size....)
