Motor Build
Old Apr 11, 2011 | 07:00 PM
  #121
bfife's Avatar
bfife
still plays with trucks
Hey Matt, glad to see you on here.
Cory, looks like some good stuff!
I definately have camshaft envy
Barney
  #122
bfife's Avatar
bfife
Barney
Old Apr 11, 2011 | 10:47 PM
  #123
Bonanza35's Avatar
Bonanza35
Cory thanks. I didn't think you wanted to turn a whole of RPM'S to make that power but wasn't sure. Street able HP is whats its about to me. And I know these heads are crab. But it would take some testing to keep them good on the tork curve down low. You are very informative and I appreciate your time. That quarter point on the cam should make a difference. I can't be at RRE so please keep us posted on the final results. I would like to give it a try someday myself. Once a hobby always a hobby, old or not I still like to build things. Chet
Old Apr 12, 2011 | 06:21 AM
  #124
rat49f6's Avatar
rat49f6
Matt great to have you spreading your knowledge here too. Thank you for the explanation
Old Apr 12, 2011 | 02:46 PM
  #125
Ziggy.'s Avatar
Ziggy.
Originally Posted by mattr66
The stage 1 works well because it quits giving a crap about drive pressure and also helps cure surge if any was present. Dyno tests only picked up 6 HP on a 38r when switching from a 1.0 to a 1.15 housing (on a truck with the stage 1 cam) when most of the time they pick up 15HP or more. EGTs are cooler as well when towing and crusing because of deeper breathing and ability to fill the cylinders with a denser air charge. When you hit the limit of the typical small exhaust wheel like on a 38r you will still see high drive pressures and high EGTs. The WOP turbos and other modded H2e style turbos will do well when teamed up with the stage 1 cam.
International designed the T444 to go in a medium duty truck and tool around at 1700 RPMs all day. They should have re-designed the camshaft for the F series in my opinion, but then again it does just fine for a stock truck at stock HP levels.
Great to see you over here Matt! thanks for sharing.
Barney
Hey Barney how goes it? Thanks, you could have yourself one too, just a day or 2 to pull the motor lol
No problem Chet, I am building this motor to still be at a pretty safe and reliable hp, have great fuel economy, plenty of power, and still be able to drive it and tow with no problems at all, and I believe that I have a great combo.
I will keep it updated at RRE isn't too far away, I will have some dyno numbers and chart after then.
Old Apr 23, 2011 | 12:21 PM
  #126
Ziggy.'s Avatar
Ziggy.
ok fellas, the motor is still apart in the garage, I will put it together here in the next day or so before I have to go to work, the motor is getting swapped the 1st of may.
I will post up pics and all when I get everything together on the motor for you all.
Old Apr 23, 2011 | 12:28 PM
  #127
orng1's Avatar
orng1
Any updated pics yet?
Old Apr 23, 2011 | 12:34 PM
  #128
Ziggy.'s Avatar
Ziggy.
nope not yet, I only have the crank rods and pistons in the block right now. I will be putting it all completely together in a few days so the pics will come alont shortly.
Old Apr 25, 2011 | 08:10 PM
  #129
Ziggy.'s Avatar
Ziggy.
Old Apr 25, 2011 | 08:42 PM
  #130
Ziggy.'s Avatar
Ziggy.
Old Apr 25, 2011 | 08:43 PM
  #131
Ziggy.'s Avatar
Ziggy.
Rear main oil seal and plate, be sure to not bend or tweak either, or it will not seal correctly
Old Apr 25, 2011 | 08:45 PM
  #132
Ziggy.'s Avatar
Ziggy.
If the ring gap measured is too tight, take a file and take some material off one end of the ring until the proper spec is obtained.
Old Apr 25, 2011 | 08:52 PM
  #133
Ziggy.'s Avatar
Ziggy.
Stock intake valve bowl
Part of the way through, most of the porting is done, the only other thing I did was smooth everything over and polish.
Old Apr 26, 2011 | 12:45 AM
  #134
ChunderDownUnder's Avatar
ChunderDownUnder
Great pics and tips Corey. reps to ya bro
Old Apr 26, 2011 | 03:02 AM
  #135
homesteader's Avatar
homesteader
Yeah great info there..........
