Taurus Fan Installation
Old Apr 19, 2011 | 01:30 PM
  #181
jsutton's Avatar
jsutton
60/40 is the percentage each part of the seat takes up. The drivers side seat is 60% because of a fold down arm rest usually, and the passenger seat is 40% because it's only a seat.
I have a seat from a 93 in mine. It's a solid bench but has headrests and fold down arm rest in the center.
Old Apr 19, 2011 | 09:35 PM
  #182
kodiak61's Avatar
kodiak61
Ok, finished the 3g swap last weekend. Just finished installing a 50k HEI with some new wires and plugs. Got everything timed and all is well in toon town.
Now I have this MarkIII fan and a 200amp solenoid (looks like a starter relay) staring at me and wondering when I'm going to install them.
My question is I want and prefer to have the control over my fan and fan speeds. I do not want anything to come on automatically. I actually prefer this and it is one of the reasons why I want to get rid of my clutched fixed fan. I would like my truck to have the ability to warm up and then I manually turn the fan on low at my desired temp. Should it get hotter I could then switch it to high.
In my ideal world I will buy a three posistion switch (off, low and high) and install this set up in my rig.
Is there someone reading this that could sort of give me a wiring for dummies lesson on what I need to do? Also do I need something more then the 200amp solenoid and the switch? I know it sounds stupid, but yes I really do need my hand held whenever it comes to wiring.
Thanks in advance,
Andrew
Old Apr 19, 2011 | 09:41 PM
  #183
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You would use the 200 amp solenoid for HIGH and another relay (Bosch 40 amp) for LOW.
For the BOSCH:
30 is battery IN
87 is Power OUT
86 is ground
85 is trigger IN... so Key-on voltage to toggle, triggered wire from toggle to 85
Use an On-OFF-On toggle.
Josh
Originally Posted by kodiak61
Ok, finished the 3g swap last weekend. Just finished installed a 50k HEI with some new wires and plugs. All is well in toon town.
Now I have this MarkIII fan and a 200 solenoid (looks like a starter relay) staring at me and wondering when I'm going to install them.
My question is I want and prefer to have the control over my fan and fan speeds. I do not want anything to come on automatically. I actually prefer this and it is one of the reason why I want to get rid of my clutched fixed fan. I would like my truck to have the ability to warm up and then I manually turn the fan on at my desired temp. Should it get hotter I could then switch it to high.
Thanks in advance,
Andrew
Old Apr 19, 2011 | 11:13 PM
  #184
kodiak61's Avatar
kodiak61
Bosch 40 amp relay.
Outstanding, thats is what I was missing. Also I like the on off on switch too, that will make it nice and easy.
Thanks allot Josh, those were the answers to the questions I had.
Once I track down the bosch I will get this bad boy installed and move onto the next little goodie.
I love the information I have found on this forum and the help from its many great members, my truck loves it and them even more.
-Andrew
Old Apr 20, 2011 | 12:06 AM
  #185
Bullitt390's Avatar
Bullitt390
Bosch 40 amp relay.
-Andrew
The 74 black truck has the MarkVIII with the toggled High and Low. It's never been an issue for me as far as paying attention to the temp gauge and switching on LOW. I have never needed HIGH speed so far in any situations I have been in. Also, when I have switched on LOW I usually just leave it on and let the t-stat regulate the temp. With a 195 t-stat the temps hold a steady 198-200, stop-n-go or highway. As a matter of fact I can usually turn the fan OFF when I hit 50+ mph and still hold the same steady temps.
Beat that FIXED MECHANICAL FAN!!!
All kidding aside... I do plan on also converting my 87 Ranger to the MarkVIII, but likely will do an automatic LOW and switched HIGH... why?
Just because really, something different. Also, with the issues of the 2.9 V6 cracking heads I may run that engine cooler (185 or so) than I usually preach on here.
Josh
Old Apr 20, 2011 | 02:31 AM
  #186
F-250 restorer's Avatar
F-250 restorer
Josh--
What made you go with 200 amp solenoid/relay? I know you mentioned burning some smaller ones.
Old Apr 20, 2011 | 07:52 AM
  #187
Bullitt390's Avatar
Bullitt390
Originally Posted by F-250 restorer
Josh--
Me?... The poster above already bought the 200 amp relay no reason not to use it. It would be massive overkill for LOW though...
But then again those continuous duty solenoids are fairly cheap and bombproof, might be good to use in the long run over Bosch's.... But the Bosch's can be bought at any parts store.
Oy Vey choices choices choices
Josh
Josh
Old Apr 20, 2011 | 08:54 PM
  #188
kodiak61's Avatar
kodiak61
The 200amp is what I had laying around from some farm equipment we were working on so I figured it would work and set it in the markiii pile to wait for its turn to install.
Picked up the 40amp relay today for the low.
Will get started here shortly on the swap.
Old Sep 6, 2011 | 09:45 PM
  #189
Yacomash800's Avatar
Yacomash800
how many of you guys use a thermo switch in the t-stat neck? thats where i put mine and it does not seem to be working to well. 1977 f-150 460
Old Sep 6, 2011 | 11:04 PM
  #190
Bullitt390's Avatar
Bullitt390
I wouldn't think it would either. Some utilize that location no problem, others have fits. I think part of the reason is no coolant is flowing for the most part until the t-stat completely opens at it's set temperature. By then it may or may not be too late to kick on the fans to start cooling things down.
Just a theory. I also think the temperature "probe" needs to be submerged in the coolant and not just located above the flow where it doesn;t get full contact like the stock location.
I have used the input heater hose before and it worked quite well, always submerged and a constant flow of heated coolant.
Do not use the return hose from the heater core for obvious reasons. The only caveat is having to run a ground wire to the sender when it is spliced into a rubber hose.
Josh
Old Sep 7, 2011 | 07:57 AM
  #191
i-w's Avatar
i-w
Excelent wire diagrams on this link.
Mark VIII & SPAL V3
read post 28 and post 33 on page 2. one diagram shows how to have Light LED
indicators when fans are on for high low and AC
Old Sep 7, 2011 | 08:24 AM
  #192
jsutton's Avatar
jsutton
I don't have the same type of temp probe you're talking about, but I do have the probe on my thermo switch fed halfway down the top radiator hose (basically the same position your talking about). I fed it down the hose and made sure it was sitting on the bottom side of the hose. My fan cuts on and off just fine with it set up this way. Then again I'm running a pretty stock 302 and you have a 460.
Old Sep 7, 2011 | 02:11 PM
  #193
Yacomash800
im an electrican, i have no problem wiring it. i didnt think about the coolant not hitting the sensor in the t-stat neck. which way does the coolant flow? does it go to the radiator in the top hose ? or go from the radiator to the engine in the top hose?
Old Sep 7, 2011 | 02:35 PM
  #194
jsutton's Avatar
jsutton
Into the radiator at the top hose, cools as it flows down and back into the engine through the bottom hose.
Old Sep 7, 2011 | 04:45 PM
  #195
Yacomash800
Then maybe i should put the temp sensor at the bottom hose, so it knows when the coolant is cooled down enough. what do you guys think?
