Glow plug sticky cleanup thread
Old May 28, 2010 | 09:48 AM
  #166
JamesHajek's Avatar
JamesHajek
Neal, do you have a picture? maybe that might be helpful for our newcomer.
Old Jul 11, 2010 | 12:02 PM
  #167
Irv Nichols's Avatar
Irv Nichols
long crank time
Hi all this is my first post here but have been reading and learning a lot from here my truck is a 95 f350 powerstroke auto 4x4 I bought it at an auction not running someone had butchered a remote start in it at one time then just cut the harness right off at the ignition switch when they removed it I repaired all of that [ soldered&heatshrank] chargedthe batteries cranked the daylights out of it & it started & romp romp romp so i read this collum & went back and checked the glow plugs fond a bad relay 2 bad plugs 1 burnt harness conector under the turbo inlet and 2 burnt conectors under the valve covers so it got everything plugs relay undercover harnesses and the one conector next to turbo changed the oil & filter 15w40 & motorcraft filter checked the hipressure pump reservoir level its ok fully charged batteries & tried it but it still seems to crank excessively 5 to 15 seconds haven checked that with a watch though not sure where to go next Thanks for any help past present & future Irv One other thing i dont belive the tach is moving when in crank position but works ok when engine is running thanks again 95 f350 60 f350 96 f150
Old Aug 20, 2010 | 09:03 PM
  #168
OldStroker's Avatar
OldStroker
Never mind. 1 yr old GD got ahold of the keyboard while I was reading this thread!
Yikes!
Old Oct 2, 2010 | 06:17 PM
  #169
zombiediesel's Avatar
zombiediesel
thanks for the suggestion. after a few minutes of playing aroung i got the gpr to kick on. still wont start i do have another thread going. with a few idease being thrown out there but still no start.
Old Oct 6, 2010 | 08:56 PM
  #170
Jesse97psd's Avatar
Jesse97psd
If you want glowplugs go to www.accuratediesel.com. They have dual coil glowplugs for any ford or any diesel. They are bout $75 for a set. You can also get a new relay too.
F2504x4
General Chapter Discussion
May 10, 2004 07:16 PM
buzzard
Jul 18, 2001 01:10 AM
dwc
1983 - 2012 Ranger & B-Series
Jun 7, 2001 01:08 AM
sticky
1978 - 1996 Big Bronco
Mar 21, 2001 12:09 PM
