Glow plug sticky cleanup thread
Old Nov 25, 2007 | 06:43 PM
  #76
sgfyrfyter's Avatar
sgfyrfyter
Been lurking for awhile and got a lot of good information off this site. Now I am having the cold start issues with my '96 PSD. It starts fine when it is plugged in, but takes awhile if it isn't. It runs smooth when it does start up so I think the GP's are OK, I did the test light on the GPR and it stays on for about a minute and a half. I did get it to fire after cycling the GP's 4 times at about a minute and a half each time. Is this just going to have to be my ritual or should I check something else? Also, I get white smoke coming from under the hood when cranking it over when it is cold, is that normal?
Old Nov 25, 2007 | 08:44 PM
  #77
FARM69's Avatar
FARM69
I still got noticeable smoke with mine on a cold start. Always starts up though. Everything is new except for the VC gaskets. So if your replacing the gp's pry be a good idea to do the vc gaskets too.
Old Dec 8, 2007 | 06:03 PM
  #78
arkredneck's Avatar
arkredneck
i noticed my truck white smoked for a while idleing this morning is there anything else that could cause that but glow plugs
Old Dec 26, 2007 | 03:49 PM
  #79
'00RedSD's Avatar
'00RedSD
2000 7.3 with k&n kit, hypertech programmer set on #2. Hard to start in the cold, 45 or lower. Smokes when trying to start and runs ruff for a few seconds after start. Batteries are good, had them tested, new bat conectors.. Changed the GPR.
I ohmed the pass side and they all read 1.4 or 1.5.
The driver's side all read 0.0, I doubled checked the common and tried again and the same 0.0.
Any suggestions?
Old Dec 31, 2007 | 10:40 AM
  #80
realpower's Avatar
realpower
Hi there!
New to the forum, read all of this thread...
I have a 2000 that is starting to get hard to start in the morning. It always starts, but recently (as its been colder I guess?) It has been starting and romping (romp romp romp romp) If I hit the gas it smoothes it out but doesnt rev past 1200 or so for a few seconds, and it is slow as hell for a mile or so. It pushes a little white smoke, not excessive. Is this low oil pressure in the HPOP circut, or glow plug related? any help would be appreciated!
Old Jan 3, 2008 | 01:05 PM
  #81
1969fordguy's Avatar
1969fordguy
I hate the cold.
My truck won't start. Again. SO I drove my $300 1976 RV to work today. I hate the cold.
So I was rereading this post for my next thing to fix on the $14,000 truck (see how I got to work today, above) and I got to thinking... How long should the GRP-109 last? I put one in two years ago (along with glowplugs).
I'll be checking the resistance of GPs, ICP unplug test, fuse #22, block heater, and recharge my new 1000 cca batteries.
I hate the cold.
Old Jan 4, 2008 | 09:35 AM
  #82
IceboxFX's Avatar
IceboxFX
good to hear it worked out for you. I had to replace my GPR last winter and got it from napa, but they charged me like 50 bucks. guess i should look forward to replacing it again next year :/
Old Jan 11, 2008 | 09:42 AM
  #83
ToyoDiesel's Avatar
ToyoDiesel
I have had this cold start problem for a couple of weeks, but today the truck will not start on a 50 degree morning!
I changed the GPR and had the batteries checked. The truck turns over and catches but will not start. The tach is moving.
I couldnt find the block heater before but I foud what looks like a 120v plug just below the driver's side battery. Is that it?
Old Jan 11, 2008 | 10:16 AM
  #84
Trakk's Avatar
Trakk
yep. that's it.
Old Jan 13, 2008 | 12:10 PM
  #85
ToyoDiesel's Avatar
ToyoDiesel
After plugging in the block heater the truck started with no problem after about two hours. I guess the oil is te problem. I just changed the oil a few weeks ago, and as a rookie I filled it with 15w. I had no idea that the oil could make a difference as far as cold starting.
Old Feb 13, 2008 | 03:32 PM
  #86
Racer100's Avatar
Racer100
Originally Posted by tjbeggs
Yep what Bill said. You have a 99 so you have 1 9 pin connector at each valve cover. the 2 outside pins on each end are your 4 GP's pins. The 94.5 to 97 trucks have 2 five pin connectors on each valve covers thats why the confusion.
First, thanks for such a quick response.
So, is it the 2 outside pins on each end of the plug, or just 1 on each end?
Thanks again
Ted
Old Feb 13, 2008 | 05:04 PM
  #87
Racer100's Avatar
Racer100
Thumbs up
2 on each end. 4 total per connector.
gg i i i i i g g
G-glow plugs
I-injectors
Thanks guys, I appreciate all the help.
Ted
Old Feb 15, 2008 | 09:08 PM
  #88
levim's Avatar
levim
Gotcha...yeah, i was doing some looking around and thats what people were saying...what do you recommend that I should use?
Old Feb 16, 2008 | 02:00 PM
  #89
levim's Avatar
levim
Thanks! I found Motorcraft on Oreillys, and they are affordable...thats the way I think I'll go...
Old Feb 22, 2008 | 06:13 PM
  #90
Stroke'NPower's Avatar
Stroke'NPower
Sounds easy enough, I will let you all know how it turns out, I have to deal with it for a day or two more... work sure gets in the way of life.... ;-)
