Duraspark II Conversion - How To
Old May 7, 2016 | 06:53 AM
  #241
Gary Lewis's Avatar
Gary Lewis
Yes, that should be the right module.
Old May 7, 2016 | 09:44 PM
  #242
Efj59's Avatar
Efj59
Summit
Do you know if the wiring harness from Summit has the wires for the temp sender and the oil pressure unit? Thanks.
Old May 8, 2016 | 06:35 PM
  #243
hillcountryflt's Avatar
hillcountryflt
Would not think that would apply to this harness. May be mistaken.
Old May 8, 2016 | 08:14 PM
  #244
Black Ford XLT's Avatar
Black Ford XLT
Hill country your right , summits sells a lot of harnesess , Painless? is does not
Old May 9, 2016 | 09:48 AM
  #245
Efj59's Avatar
Efj59
Duraspark
Thanks, I'll just keep my old wires for the temp sender and oil sender
Old May 9, 2016 | 10:49 AM
  #246
Black Ford XLT
EF, you have a sender to the gauge and a sensor for the computer. On my 1985 sender to gauge is rear passenger side, where the sensor for the computer is up front on the coolant neck. The wiring harness does have the gauge sender and not the sensor for the computer. TR
Old May 9, 2016 | 10:52 AM
  #247
Black Ford XLT
EF, sorry I stand to correct neither is included . I used stock sender for my duraspark ignition swap. Sorry TR
Old May 9, 2016 | 04:37 PM
  #248
Mookie's 85's Avatar
Mookie's 85
I recently picked up a Motorcraft 2100 carburetor with a 1.08 venturi size for $25 (requires a rebuild). Is it a good carb to use for a Duraspark II conversion for my 4.9 300L six?
Old May 9, 2016 | 05:06 PM
  #249
Gary Lewis's Avatar
Gary Lewis
The 2100 is a good carb, and with 1.08's it flows 287 CFM @ 3" of mercury, which is where a 1 and 2bbl carb is rated. But, that's only 203 CFM at 1.5" of mercury, which is where a 4bbl carb is rated.
This thread talks about the max carb size for the 300 six: https://www.ford-trucks.com/forums/8...er-yf-cfm.html
Old May 9, 2016 | 05:50 PM
  #250
Mookie's 85
Thank you Gary ...much appreciated.
Old May 9, 2016 | 09:04 PM
  #251
Efj59's Avatar
Efj59
Thanks. I'm going to order the harness from Summit. From what your saying, I can use the wire to my temp sender which is located on the passenger side of the engine at the rear and should be able to use the wire going to the oil sender which is located on the drivers side at the rear of the engine. I guess I should be able to get rid of the coolant sensor that goes to the computer once I install the duraspark distributor and ignition module.
Old May 10, 2016 | 01:02 PM
  #252
1986F150six's Avatar
1986F150six
Through the years, I have read numerous "guestimates" of what is the flow of Carter YFs or YFAs and the general consensus is 187-215 CFM, so 287 CFM @ 3" would be an improvement in flow as compared to the stock carburetor.
Old May 11, 2016 | 03:48 PM
  #253
xsn10s's Avatar
xsn10s
It's sounds like my 1986 backfeed truck should be a plug and play with the DS2. I was curious what the "half moon" deal is, for lack of a better description, on the wire harness? Thanks, John
Old May 11, 2016 | 03:53 PM
  #254
AbandonedBronco's Avatar
AbandonedBronco
That is a clip that goes onto the coil. It makes it so that you can just clip it on as opposed to having to tightening down the nuts/wires onto the Pos/Neg studs on the coil.
However, you have to have a coil made specifically for it. Notice how the positive and negative studs are just prongs, instead of threaded studs with a nut.
Old May 11, 2016 | 04:03 PM
  #255
xsn10s's Avatar
xsn10s
Perfect! Thanks AB!
