Carter YF cfm?
Old Jul 5, 2009 | 12:07 AM
murph77's Avatar
murph77
Carter YF cfm?
I feel like a fool having to ask this question, but I can't find numbers anywhere.
What is the cfm rating for a '75 Carter YF one barrel carburetor?
If you wanna poke fun at me for being a dummy, go ahead.
Just be sure to give me the numbers.
Murph.
Old Jul 5, 2009 | 06:37 PM
murph77's Avatar
murph77
Any rough ideas?
Old Jul 5, 2009 | 07:24 PM
fmc400's Avatar
fmc400
MSEE
For some reason, 170 CFM is sticking out in my mind. Since they are 1-barrel and they are typically found on straight sixes which are intended to work at low RPMs, YFs generally have relatively low flow numbers. The CFM an engine calls for is a function of RPM and displacement.
Old Jul 5, 2009 | 11:23 PM
murph77's Avatar
murph77
Although I can't find a concrete number, the number you
are recalling kind of matches what I've been hearing.
I'm trying to gather some sketches for a rebuild I'll eventually do.
The CFM/RPM equation I found tells me that 350 CFM might suit me well.
Some of my snooping around these forums has led me to believe
that an Autolite C90F might fit my application.
I need to know more about it's CFM rating, that post might pop up soon.
In the mean time, thanks,
Murph.
Old Jul 6, 2009 | 05:33 AM
BigBlue88's Avatar
BigBlue88
196CFM, I believe, but that's 2BBL spec (3.0in hg). 4bbl spec (1.5in hg) makes it somewhere around 165-170CFM. 350-400CFM is all these motors will really handle. Holley 390 is popular, but needs to be tuned out of the box (it'll run, but not right). If you can find one, an old Holley Economaster 450 is a good carb too. People run 500's, but anything much above that and they're probably just running on the primaries. 2100/2150 2BBL carbs are popular too (1.08" venturi size). I think that ends up being somewhere around 300CFM 2BBL rating, and a real smooth driver.
Nod
Apr 10, 2017 09:10 PM
chrlsful
Dec 15, 2015 06:24 PM
racerx6466
S. California Chapter
15
Sep 5, 2015 08:21 AM
spongecop
Feb 7, 2011 07:41 PM
Buddhaventura
May 11, 2010 07:06 AM
