Duraspark II Conversion - How To
Old Feb 18, 2014 | 04:43 PM
  #91
Memphis_Sean's Avatar
Memphis_Sean
Yes, it seems easy, until you throw California Emissions in there and extra wires...that no one seems to have seen before LOL...I do have the three plugs on my engine wiring harness, as seen in an earlier pic (this thread). I'll just figure...if it plugs in (keep)...if it doesn't plug in (don't need)/smiling (hopefully that logic works)
Old Feb 18, 2014 | 05:17 PM
  #92
Gary Lewis's Avatar
Gary Lewis
I know on an 82 I had the DS-III and EEC stuff was completely separate from the basic wiring. Dunno if that's true for the CA stuff. But in my case I was able to remove the stuff I didn't need w/o cutting or splicing any wires I was keeping.
Old Feb 18, 2014 | 05:29 PM
  #93
Memphis_Sean
I have yet to match wire to wire (it will have to wait until the weekend). I'm hoping and it looks like the 5-wire harness (82 I6), I can just eliminate the extra 2-plugs and wires (they're separate). The 3-wire harness should match right up...but its pretty short.
Old Feb 20, 2014 | 08:37 PM
  #94
Memphis_Sean
The 5-plug harness, had a double yellow 3-plug module...what is the yellow module??
Old Feb 20, 2014 | 08:41 PM
  #95
Gary Lewis's Avatar
Gary Lewis
Can you post a picture? It would help a bunch.
Old Feb 20, 2014 | 08:44 PM
  #96
Memphis_Sean
The 5-plug picture, is posted above. I don't have a pic of the module...I can find one on Google, etc if you need it.
Old Feb 20, 2014 | 09:01 PM
  #97
Gary Lewis's Avatar
Gary Lewis
I doubt I can ID the module if I don't know what it looks like. I don't mean to be sarcastic, but I don't recognize the description. Maybe if I see it?
Old Feb 20, 2014 | 09:09 PM
  #98
Memphis_Sean
I'm on mobile, so I can't post pics right now. It has 3iplugs and two yellow grommets...you can Google too if intereted.
Old Feb 20, 2014 | 09:25 PM
  #99
Memphis_Sean
Here is a link, to another question I just found (I guess its high altitude). https://www.ford-trucks.com/forums/showthread.php?t=1061916
Old Feb 20, 2014 | 09:45 PM
  #100
Gary Lewis's Avatar
Gary Lewis
Ahhh! Now I understand. Sorry, just didn't understand what you meant. You only want a blue grommeted module. There are a number of sites out there that explain what the various grommet colors represent, but that's a moot point - you want blue.
Old Feb 20, 2014 | 09:47 PM
  #101
Memphis_Sean
Right, but can I use the harness from the yellow module (5-Plug harness above)?
Old Feb 20, 2014 | 09:52 PM
  #102
Gary Lewis's Avatar
Gary Lewis
If you can get it down to the standard 3 plugs then yes.
Old Feb 20, 2014 | 09:54 PM
  #103
Memphis_Sean
I'll know this weekend one way or another
Old Feb 20, 2014 | 10:04 PM
  #104
Gary Lewis's Avatar
Gary Lewis
Wikipedia says the yellow grommeted module was used from 79 to 81. If that's true then I think you can extract the other plugs and wires. I say that because up through '82 the ones I've worked on have had the computer or emissions stuff separate. You may have to cut some of the emissions wires to get them out of the harness, but I think the two plugs will be separate.
Old Feb 21, 2014 | 01:22 AM
  #105
Memphis_Sean
The 5-Plug harness w/yellow module, came off of an 82' Bronco I6. It looks like I can just eliminate the two extra plugs. Does anyone have a DS II wiring diagram, that shows wire colors/how many wires, etc??
