I recently picked up a Motorcraft 2100 carburetor with a 1.08 venturi size for $25 (requires a rebuild). Is it a good carb to use for a Duraspark II conversion for my 4.9 300L six?
For everyday use it is the most popular carb size. Go bigger if performance is your only goal.,...jack
As to the Duraspark conversion on our 240/300 engines running with the standard Carter YF or Motorcraft carbs - this upgrade does not provide any performance increase, correct? Basically meant to provide a more reliable ignition system, yes?
A step above the Pertronix-type of upgrade?
If you're switching from a worn out TFI system yes it's probably more reliable. Definitely more simple, the TFI system has a myriad of wiring and vacuum lines. The performance increases with the DS2 would come from different combination with intakes, carbs, and exhaust. I'm a newbie, all this knowledge is book read from me. I can't say which is a higher performance upgrade between the DS2 and Petronix. I would guess they're pretty close to equal with DS2 parts more readily available. DS2 would be a performance increase over a points distributor.
Hope that helps.
I'll say this. My truck started out as a TFI system which I got running back from a terrible state. I then switched to a points system because of the simplicity which should equal reliability. If I had it to do all over again I'd go to DS2 because of all the knowledge on this board dealing with DS2. Or a DUI unit if money was no object.
here's a newbie question. Does the wiring harness have to come from a rig with a straight six? Or will any DS2 wiring harness work on my 1986 300-6?
Yes, and no. It may work depending on which V-engined harness you get.m That's because the harness has the wires to the temp and oil pressure senders in it, and each engine family has those in a different place. So, one for an M/400, which has the oil pressure sender at the rear of the block would have a long enough wire for the 300 six, but one from a Windsor may not. But, you can shorten or lengthen the wires and make it fit.
Also, the V8 harness has a ground for the tach that tells it the engine will fire 4 times/revolution. So, if you have a tach and put an 8-cylinder harness in your tach will read incorrectly unless you remove that wire.
Yes it's just harder to find the harness where I am currently at. But it's still a good option to use the harness from other rigs. Splicing the wires isn't hard. But the tach I might have to figure something else out.
Duraspark II reliable yes , my main reason was the feedback carb and all the sensors etc . The computer takes feedback from every sensor and I guess in lay mans terms, readjusts it per spark and fuel. Our old systems (at least mine) was doing bad on fuel mileage. Best swap I have made . Good luckTR
Yes the feedback system (TFI) had a ton of sensors and vacuum lines. Any leaks and it can be a nightmare. When it works it works great. I got 17 mpg with a full load of firewood. When there were leaks it could get 8 mpg. And a PITA to troubleshoot.
I truly agree . No computer, no problems , currently getting 15,( running 32-11.50x 15 tires). My upgrade was the Cliffords system , weber 38-38 progressive carb, long tube headers, x pipe and a set of magnaflow exhaust (dual).Just installed a electric fuel pump(redline) .This truck has over 600000 miles .TR
Yes , I bought this truck new in sept 1984 $9200, had ac no radio 4 speed(granny gear) and bench vinyl seat with sliding rear glass .My work commute once was 48 miles one way , then 55 miles one way. I have pulled boats , over the years and currently have a 24 foot and 6 x12 trailer .I rarely pull tractors , motorcycles and recently pulled a four door 2004 dodge truck(fuel)(pump went out) Crusing at 45 it ran great but its a short wheel base .The airbags help even the load.TR
