no power to cab
Old Sep 25, 2004 | 02:37 PM
bulldog77's Avatar
bulldog77
no power to cab
I have a 77 ford f250 with a 400m. I just to the engine out to freshen it up last week end and when i put it back in the last thing i did was hooked up the battery and the selinoid started smoking. So i got a new one hooked it up but now nothing happens when i turn the key and the lights, nothing works. when i jump the posts with a plyers the engine turns over. i can't figure it out any help would be great.
thanks bulldog.
Old Sep 25, 2004 | 05:18 PM
hdgapeach's Avatar
hdgapeach
Smoking wires! Fuse links probably fried too. If any of the wiring, including the battery cables got any insullation damage, I would replace them, or at the very least inspect them very close.
Old Sep 25, 2004 | 10:35 PM
bulldog77's Avatar
bulldog77
I checked the links they look good. i unpluged the wires from the ignition switch and i am getting no power to any of the wires. could some one tell me witch wire is suppose to hot going to the ignition switch. would a bad voltage regulater cut off power to the ignition switch? there is a yellow wire comming off the starter selinoid big post closest to the battery. It is hot going up the the voltage regulater then i have nothing comming out. i used a test light to check the wires out. it is an automatic transmission so would the nuetral safty switch cause this problem. any help would be great.
thanks bulldog
Old Sep 26, 2004 | 08:51 AM
73Custom's Avatar
73Custom
I think hdgapeach is right. Each of the wires on the battery + side of the solinoid have fuse links on them. Use a test light and stab the wires about 6" from the solinoid end. I bet you find at least one with no power. The fuse links burn internally and may appear fine from the outside. Just buy a replacement piece from the parts store and solder it in.
Marty
Old Sep 26, 2004 | 06:07 PM
Franklin2's Avatar
Franklin2
There should be a wire coming off the big post like you said. Follow this wire down, and it should split into several other wires, one which is a yellow which runs toward the firewall and feeds the ignition switch. Probe this wire like the other guys said for power.
kwimer4594
Oct 24, 2013 10:30 AM
bulldog77
15
Jan 3, 2006 08:47 AM
bulldog77
Mar 29, 2005 08:05 PM
bulldog77
Oct 20, 2004 03:27 PM
bulldog77
Mar 4, 2004 03:07 PM
