No Spark
Old Sep 28, 2004 | 11:32 AM
Dave874.9L's Avatar
Dave874.9L
No Spark
I had spark on Sunday, but lost it once I fixed the Gas problem and put a new battery in. I have replaced the cap, roder, plugs, coil, had the electronic module checked, the 87 4.9 L cranks over but I can not get any spark to the plugs or even to the top of the distributor from the wire coming from the coil.
What else is there to check or replace to get the spark back?
Old Oct 18, 2004 | 08:21 PM
Larry_the_handyman's Avatar
Larry_the_handyman
Cool Ahoy, we're in the same boat
I have the same problem as you. My starter began turning slower and slower over two days, then died completely. I replaced it, put in a fresh battery and enjoyed myself emmensely. It ran great, but then wouldn't turn off. I didn't have time to keep messing with it, so i just but my foot on the brake and stalled it out. The next morning, I ran an errand, the truck was fine, still wouldn't turn off. That afternoon, I have NO SPARK. I checked the voltage at the cool, swapped the coil. Still nothing. I want to know why the spark is gone when nothing has changed. If I get an answer/solution first, I'll let you know. Good luck.
Larry
Old Oct 18, 2004 | 10:04 PM
Franklin2's Avatar
Franklin2
Pull the codes on these trucks to see if you have a PIP signal loss. This is the signal form the dist to the computer.
Old Oct 18, 2004 | 10:18 PM
Larry_the_handyman
Hmm...let me tell you what I have. I have a stock 1960 F-100 with a 292 V-8. Between the battery and the spark plugs, we have wires, coil, distributor and more wires. No computer to foul things up. Any ideas? anybody?
Larry
Old Oct 19, 2004 | 04:34 PM
classic80bird's Avatar
classic80bird
No spark either
I can relate! I've got an 86 that is doing the same thing. So far: new coil, distributor, ignition module, stator in the distributor, and finally, new Electronic Engine Control. So I'll be watching to see what you come up with!!
Old Oct 19, 2004 | 04:43 PM
Franklin2's Avatar
Franklin2
Your problem sounds like the wires on the starter solenoid got put on backwards. If you have two large wires, and two small wires, you may have put the large wires on the wrong sides. One of the small wires goes to the coil +. If some of these wires got mixed up, then that would explain why it won't cut off. And the final blow was probably because the ignition is on all the time, you have burned up your points. You may have burned up the coil too, but you said you replaced that.
Old Oct 20, 2004 | 03:26 PM
Larry_the_handyman
Well, I'm an engineer, so I'm hoping that i can handle two wires. The wires were in the right place all the time. I have no doubt about that. But I do believe the starter solenoid was shorted internally. I replace the points and condenser with an Accel high performance set I had laying around. WOW...it runs sooooo nice right now. Thanks for the advice.
Larry
PS - has anyone else ever had a starter solenoid go suicidal?
Old Oct 20, 2004 | 07:57 PM
Dealford's Avatar
Dealford
"Suicidal" is why I only use Ford solenoids now. The last aftermarket switch only lasted 2 starts & stayed engaged.
AL.
Old Oct 30, 2004 | 01:29 PM
ninerocket1's Avatar
ninerocket1
Been here before
I had an 86 do this to me and now my 89 5.0L is doing the same thing. Replacing the ignition switch fixed my old truck and I am about to do the same thing to the truck I have now. I'm definitely just guessing, but it's a really inexpensive part and not to bad to replace. Hope this helps
ymirr
Apr 6, 2017 07:42 PM
THAT.GUY
19
Jan 12, 2013 03:00 PM
tjs_79ford
Sep 20, 2009 11:30 AM
nova801428
1983 - 2012 Ranger & B-Series
Oct 24, 2007 09:35 PM
RangerBlues
Electrical Systems/Wiring
Dec 14, 2006 10:15 AM
