1992 E350 Rear Turn Signals/Cruise control don't work
Hi all, I Have an E350 RV that the rear turn signals don't work, running lights work. The front signals work but flash really fast. I also noticed the cruise control stopped working and my ABS light came on too? Need some direction on this, all fuses okay. Please help. Thanks and have a great day. Jer
In that case run a long wire from the negative post on the battery(or any other ground) turn on the flashers & connect a voltmeter between your temporary ground wire & the center electrode of the bulb socket. If you get 12 volts the problem is an open ground circuit. Do you have a wiring diagram?
Menoche
08-16-2016 02:28 PM
freetorun
12-02-2015 12:53 AM
Brok
09-05-2015 06:48 PM
AADAD
1999 to 2016 Super Duty
07-30-2015 07:26 AM
