blower stopped working
Old Aug 16, 2002 | 07:49 PM
rbridges's Avatar
rbridges
Everything was fine until I cranked my truck today. Compressor works but no air blowing? Fuses appear intact. Do blowers go out that often. Never had it happen before. If so, is it hard to remove and check?
thanks
Old Aug 16, 2002 | 10:11 PM
rbridges's Avatar
rbridges
I just checked the power wire with a voltmeter and I'm getting 12 volts at the connectors-i assume it's a bad fan.
next question, how do you get it down and replace it? I can't remove the bolts near the back
Old Sep 5, 2002 | 08:53 PM
rusty75's Avatar
rusty75
not sure exactly but the blower usually bolts in with 3 bolts from the motor side into the ductwork. motor will either ohm out shorted, open, or have bad bearings. or maybe just debris stuck in the fan blade. is the motor hot? make sure your drain on the evaporator is flowing properly. water will short out the motor.
chris
Old Sep 6, 2002 | 12:06 AM
nitro94's Avatar
nitro94
If you have power on both sides of the connection at the blower motor then it is not a blower motor problem. Ford switches the ground side of the system. Check the resistor and the switch.
Old Sep 6, 2002 | 08:04 AM
tomw's Avatar
tomw
Post blower stopped working
