Temp Gauge
Old Feb 16, 2003 | 08:43 PM
klf's Avatar
klf
Temp Gauge
I have a 85 F150 4x4. I`ve put a new reman engine in. The temp gauge moves to hot when the headlights are turned on, and when I cut the heat on. If I turn the items off, the gauge goes back to normal operation range. I`m sure this is electrical problem...........WHERE?
Old Feb 16, 2003 | 08:50 PM
Bob Ayers's Avatar
Bob Ayers
Temp Gauge
Your instrument panel has a bad ground connection....
Old Feb 26, 2003 | 06:23 PM
klf's Avatar
klf
Temp Gauge
Thanks for the info. I added a few grounds to the engine and the guage is now working like it should! I had got a list of "where the grounding points are" from Alldata, then rechecked each.
Old Feb 26, 2003 | 07:50 PM
Bob Ayers's Avatar
Bob Ayers
Temp Gauge
That's great!!!......Welcome to FTE!!!!!
Old Mar 11, 2003 | 08:38 PM
coldandwet's Avatar
coldandwet
Question Temp Gauge
I've got an 94 Aerostar with the same problem
