AC switching over problems
Old Mar 11, 2003 | 01:15 PM
Tampa2003's Avatar
Tampa2003
I have a 2002 Explorer. Problem is that after a few minutes of driving with the air conditioning on in the normal vent setting the systems switches over and will only blow air on the floor and the windshield. The air conditioning stays on it will not blow out the normal dash vents. Any help is appreciated.
Old Mar 11, 2003 | 11:38 PM
Racerguy's Avatar
Racerguy
HiTampa2003 and welcome to FTE
It sounds like you have a vacuum leak to the panel door vacuum control motor. You can see the vacuum motor in behind the glove box. Check all the vacuum hoses going to the heater system and see if you can find one that isnt on tight or is split or something.
