Crank, start, and die.
Old Jul 20, 2015 | 10:16 AM
acschex's Avatar
acschex
Okay, I am having issues with a 1999 F250 XLT 7.3 with diablo programmer. I have searched and searched and have tried everything we could think of and it is a no go. The truck will crank, hesitate to start, start and die, other times it will only crank and not run at all. We can make it stay running by hitting the accelerator. The only code we were getting was the cps code, but that is suspected to be because of the excessive cranking and no start times. Previous to this issue getting this serious it would stall randomly, at idle, going down the road at constant speed, slowing down, or accelerating. We now have code P0231.
Through this we have tried:
IDM
(loaner) ECM
removing Diablo
3 CPS
shaving down CPS
Shimming CPS
IPR
Fuel pump
relay
fuel pump fuse
and probably a few things I am forgetting ATM
Any and all help is appreciated!
Old Jul 20, 2015 | 10:30 AM
Thomas White's Avatar
Thomas White
Have you checked the fuel pressure? Before, during and after starting event?
Old Jul 20, 2015 | 10:34 AM
acschex's Avatar
acschex
Before replacing the fuel pump, the pressure was around 40. now, after replacing it the pressure is between 55 and 60.
Old Jul 20, 2015 | 04:51 PM
acschex's Avatar
acschex
Has anyone ran across this issue before? We are having trouble tracing it down!
Swat_Medic
May 13, 2018 02:20 PM
Talyn
Nov 17, 2012 08:56 PM
daggerNC
Nov 13, 2008 02:50 AM
elkarcher
Apr 16, 2007 03:54 PM
maxmung2
May 3, 2004 08:20 PM
