Emergency help needed!
I'm scrambling to learn as much about Ford diesels as I can, because we are stuck AGAIN. We need help in DXing this problem with our truck.
Backstory: We have a 2001 ford diesel dually 7.3L we bought back in May of this year pulling a 5th wheel rv. We took a trip into Canada, from California, with our kids. One day, while at an RV park in Alberta, we filled up on diesel, and as we were driving back to the rv park, and I smelled diesel really bad. As we pulled into the park, we were spilling fuel all over the road, and the truck was smoking. The next day, I had it towed to a dealership (no one could figure it out? We're n00bs), who then washed off the diesel fuel with water (is this ok to do in the engine compartment?) and told us it was a loose fuel filter. We felt stupid.
The next day we started the truck, and began driving up the road, but I forgot something, so we drove back to the rv. We turned off the truck, but when we went to restart it, it wouldn't start. It turned over, but the motor would not start. The batteries showed full, there are no leaks we could see, no loose wires, the fuel reset switch was in the down position, but the oil was completely empty. We had just filled it 7 days before, and we saw no leaking.
Back to the dealership the truck went. They told us it was either the oil pressure regulator/sensor, and if that didn't work, then they would try the high pressure oil pump. They said the regulator worked, and to come pick up the truck. It seemed fine when I got it, although sounded just slightly different (no one else would have noticed).
We took our rv to Yellowstone, and drove all over Yellowstone for a couple of days, and the truck seemed fine. Then this morning, we started the truck to hook-up the rv, and turned off the engine. We got everything done, kids in the truck, and the truck wouldn't start. It sounded just like it had in Alberta! The park manager came out and sprayed starter fluid in the air intake and the truck started up. He said that it was 28* the night before and diesels don't like to start (which I knew). We got on the road, relieved the problem had been solved, but a little miffed that we'd spent $1,200 at the ford dealership getting it fixed before. But, as we came off an offramp in Idaho and had almost come to a complete stop, the truck suddenly died. We could not restart it, and sounded just like it had that morning.
A farmer helped us off the road using a chain and his truck, and he tried starter fluid in it also, and it did sputter to life briefly, and died again. He says it's like the truck isn't getting fuel. He towed the truck to the local dealership for us, and we are in his driveway! Stuck, in Idaho! Then a local RV park told us the story of another couple, they've been stuck in their RV park for a couple of weeks. They have a Ford diesel truck a bit newer than ours, and it wouldn't start. The dealership where our truck is at now has spent considerable time and has had "master mechanics" come out to look at it, but no one can figure out what's wrong with it. The couple is having to get a new truck.
We cannot afford a new truck.We are really freaked out now, and my husband has to be back at work a week from Monday, and he absolutely cannot be absent from work. Can anyone help or give us some ideas? TIA.
Try pulling the fuel filter and check to see if there is fuel fetting there. There sure was when it all ran out, but that can change. It may just be a clogged fuel pick up. How many miles on the truck?
Others here will be more help.
I wish you luck.
Riffraff Diesel can get you the good one (BLACK in color) as to they are hard to find anymore. You could just get a local auto parts one just to test and see if it runs any better.
My truck would turn over and turn over but wouldnt get fuel and wouldnt start. New CPS and BOOM starts instant.
Oh and just so you know, try not to use starting fluid unless its a DIRE emergency and in that case only use a LITTLE. Ether is NOT good for your diesel engine.
Grab a flash light and look on top of the engine down under the fuel filter bowl and turbo for any signs of oil. It's not really that uncommon to have an o-ring start to leak oil (under pressure it can leak a lot of oil).
If your husband has a week before he has to be back at work, and as long as the two of you have a basic understanding of tools and can follow directions, we can probably get this figured out quicker than the dealer can.
There is one problem: The truck is 2 miles away at the dealership, and we have no vehicle. I want to be able to understand where the dealership is coming from, and make (haha) sure that any fix they do is not temporary and cause us to break down again before getting home.
The truck has a sticker that says do not use starter fluids on it, but we were desperate. I worry we messed up the glow plug.
What is a CPS? I'm a N00b and don't get some of the terminology, yet.
We took a flashlight and looked all over for leaks, and saw nothing. We did check the oil first thing when it lost power this time, and it was full.
I do think it might be fuel starvation or water got in there somehow? But was the fuel filter really loose? The mechanic said he couldn't find anything but the fuel filter being a little loose, but maybe he bumped something, and caused it to work. or?
