Offroad & 4x4
Know what I hate?
Old May 23, 2011 | 08:39 AM
  #1456
kjett's Avatar
kjett
Dude, stop progress, leave the 250 be. Pull the motor and replace it with a warmed up 466 for the play truck and put the 521 into a purpose built race truck. It's not like you don't have 2 or 3 "parts trucks" sitting around you can build from. It'll give you the coil sprung front end, which is basically a modified 3 link deal to keep your pinion from wrapping up, and do a rear setup similar to mine, leave it low to the ground and either do a ranger body or gut the **** out of a 70's cab with bedsides.
Old May 23, 2011 | 09:44 AM
  #1457
alpha/omega's Avatar
alpha/omega
eeeeh.
<fiiiiiill>
Old May 23, 2011 | 09:48 AM
  #1458
nobodyspecial's Avatar
nobodyspecial
How much weight difference is there in the chassis between the half ton and the bigger trucks?
Old May 23, 2011 | 10:00 AM
  #1459
alpha/omega
not much I wouldnt think.
I dont know of any full bodied 79 250s that weigh less than 4500lbs race ready so gutting much more than I already have would be a waste of a good cab and bed.
Old May 23, 2011 | 11:02 AM
  #1460
kjett's Avatar
kjett
The frames are about the same. I was referring the the added benifit of the coil/radius arm front keeping the pinion where it belongs. The front leaf springs are still subjected to pinion rotation like a rear leaf spring setup is, especially in higher hp/tqe applications. And short of adding some type of ladder bar deal up there or run some super stiff leafs, when you get the power to the ground the pinion if going to try to rotate, it's a loss of power to the ground, not to mention the unneeded extra weight of that built 60 you have up there. Not trying to get you down to the 3000lb range, just make it so you can play with the guys like Johnny M.
Old May 23, 2011 | 11:10 AM
  #1461
fatdan460's Avatar
fatdan460
yep, no real need for built to hell tons on a bog truck either. they just weigh more and hang lower. just sayin' less chit touching the mud=less resistance=farther runs......
Old May 23, 2011 | 12:19 PM
  #1462
kjett's Avatar
kjett
George will make the distance, no doubt. Its the help in weight transfer to put everything to the rear and get it on top of the mud he needs.
Old May 23, 2011 | 02:24 PM
  #1463
hav24wheel's Avatar
hav24wheel
Originally Posted by alpha/omega
Im still driving the bitch to the bar when its done.
I have a pic somewhere of my wheeler along with 3-4 of my buddys wheelers sitting in front of the local bar...
Good times
Old May 23, 2011 | 07:18 PM
  #1464
crazyredneckanyhow's Avatar
crazyredneckanyhow
Hey brokeback is this what you have Buy Cardone Power Brake Booster 54-73021 at Advance Auto Parts
Old May 23, 2011 | 08:58 PM
  #1465
nobodyspecial
Got it. I thought the frames were practically the same, but misinterpreted this post:
Originally Posted by kjett
You should leave that truck alone as a ride around, hunting and play truck, and start fresh with a half ton chassis. Much less weight.
And thought that you were saying the frame was lighter.
Old May 23, 2011 | 09:09 PM
  #1466
kjett's Avatar
kjett
Nope it's the extra crap that is bolted to it that make it that much heavier.
Old May 23, 2011 | 09:17 PM
  #1467
nobodyspecial
Thats what I thought, thanks for the clarification.
Old May 23, 2011 | 10:03 PM
  #1468
whack&stack's Avatar
whack&stack
thats the spirit get drunk and wreck it nice
Old May 26, 2011 | 03:09 AM
  #1469
hav24wheel's Avatar
hav24wheel
Floods. I hate them.
Over the weekend river is suppose to rise about 4 ft. Its at the start of flood stage already.....
My place is in no danger, but a lot of peoples are.
Old May 26, 2011 | 07:15 AM
  #1470
nobodyspecial
I was in Bismarck yesterday. Have you been to the Garrison Dam since they opened it? They are letting out over 75,000 cubic feet per second. It is pretty spectacular at times. (They will be increasing release to over 80K) However, there is over 200,000 cubic feet coming in from the rivers per second. Lake Sakakawea went up 4 inches yesterday. (For those unaware, this is not a small lake. On average, it is about 3 miles wide, and 15 miles wide at its largest point. Its also about 200 feet at its deepest, being the third largest man made lake)
Here is a video of only 50,000 CF/S.
YouTube - &#x202a;Garrison Dam 50K CFS May 18 2011.MOV&#x202c;&rlm;
