Offroad & 4x4
Know what I hate?
Old May 22, 2011 | 12:36 PM
  #1441
alpha/omega's Avatar
alpha/omega
The MC should be the same. The booster depends on the serial number. The early style will have a straight rod through the firewall. The later will have a much shorter rod and a lever/pivot to the brake pedal. It wont matter if its 150 or 250 as far as I know.
  #1442
fatdan460's Avatar
fatdan460
yeah. the f150's and some 250's came with single piston calipers, so they will have the same parts, but some f250's came with dual piston calipers, and for sure the m/c is different. the dual piston m/c has both lines on the drivers side and the single piston has a hole on each side iirc.
Old May 22, 2011 | 12:49 PM
  #1443
alpha/omega
The MCs are the same for 4wd trucks.
https://www.napaonline.com/Catalog/C...+50028+2028020
Heres the boosters Cheet-hoe
long rod early style
pivot deal later style
BTW, personally I wouldnt put a 150 or 250 booster on the Crew when a 350 booster and MC arent much more money and will stop that big heavy truck much better.
short/later
long/early
https://www.napaonline.com/Catalog/C...+50028+2028036
MC
Old May 22, 2011 | 12:59 PM
  #1444
fatdan460's Avatar
fatdan460
i whole heartedly dis-a-****ing-gree with you sir. there is a single and dual piston m/c. obviously the dual is valved(or whatever) differently to move more fluid. my parts guy brought out both to show me before i bought mine a few months back. :flipoff:
Old May 22, 2011 | 01:06 PM
  #1445
alpha/omega
Hmmmm...
Ill get back to you.
Yes Dan, you are correct.
Old May 22, 2011 | 01:11 PM
  #1446
fatdan460's Avatar
fatdan460
Hmmmm...
no need to, here's the link. click on both and compare. and i was half right. the single piston m/c has the lines on the opposite side.
List: Brake Master Cylinder - 1978 Ford F-250 | O'Reilly Auto Parts
me <--:WINNING:
EDIT: damn, you edited as i posted.
Old May 22, 2011 | 01:25 PM
  #1447
alpha/omega
Looks like I need to start doing some leg excercises. :-(
Brake Master Cylinder - 1979 Ford F-150 | O'Reilly Auto Parts
Old May 22, 2011 | 04:05 PM
  #1448
crazyredneckanyhow's Avatar
crazyredneckanyhow
So i looked online and there are two different boosters. One for single piston and one for dual piston calipers. The factory F-350 unit on the crew has the long flat rod. The 4 spd pedals i put in use the short rod. I have a new master/booster here but they are from a bronco.
Old May 22, 2011 | 07:52 PM
  #1449
alpha/omega
I can sell you my 350 short rod booster and mc with the pivot lever dealio if you want it.
Old May 22, 2011 | 09:23 PM
  #1450
crazyredneckanyhow
Im interested. Give me a price shipped to 26582. I sold a 44/60 i had so i need to pick up the mc/bb and an alternator to get the crew moveable.
Old May 22, 2011 | 09:25 PM
  #1451
kjett's Avatar
kjett
You are always trying to sell that short rod dealio! Be happy your woman married your sorry azz and move on!
Old May 22, 2011 | 10:45 PM
  #1452
fatdan460's Avatar
fatdan460
bwahahahaha!!!!!! karl ftw!!!!
Old May 23, 2011 | 07:38 AM
  #1453
alpha/omega
Cheet-hoe,
I can send you the alternator also. Half price of new. 2 seasons worth of passes on both.
Old May 23, 2011 | 07:50 AM
  #1454
kjett's Avatar
kjett
Hmm, no alternator, and no vacuum boster. Looks like George is on a major diet.....
You should leave that truck alone as a ride around, hunting and play truck, and start fresh with a half ton chassis. Much less weight.
Old May 23, 2011 | 08:20 AM
  #1455
alpha/omega
Thats what I keep telling myself but for some reason I wont listen.
Im still driving the bitch to the bar when its done.
